  Temperature gauge motor works but doesn't
Temperature gauge motor works but doesn't by ironpuke84
Started on: 12-29-2021 04:17 PM
Replies: 4 (334 views)
Last post by: fierosound on 01-19-2022 08:04 PM
ironpuke84
Report this Post12-29-2021 04:17 PM Click Here to See the Profile for ironpuke84Send a Private Message to ironpuke84Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I have an 84 Fiero SE, and the temperature gauge motor works, it always moves when I go to start it, but it's always reading as if the engine is overheating (even though it's not.) Any ideas what the problem is? Thanks.
ironpuke84
Report this Post12-29-2021 04:27 PM Click Here to See the Profile for ironpuke84Send a Private Message to ironpuke84Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wrong section sorry
Australian
Report this Post01-14-2022 04:41 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
The thermostat needs to be changed and you have a choice of temperatures 150 vs 180 degree etc when the fan kicks on unless you over ride this i make mine always run and use a commodore fan much more air. The thermostat is held in by 2 bolts and you may need a gasket if you destroy old one usually comes with the thermostat.
fierosound
Total ratings: 286
Report this Post01-18-2022 05:54 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by ironpuke84:
... it's always reading as if the engine is overheating (even though it's not.) Any ideas what the problem is? Thanks.
If the thermostat and radiator fan is working properly etc. it sounds like the Coolant Temp. Sender or the gauge itself is bad.
It's also possible the previous owner messed something up in the wiring.
[This message has been edited by fierosound (edited 01-18-2022).]
fierosound
Total ratings: 286
Report this Post01-19-2022 08:04 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Temp Sender should look like this.
