  Is it possible to bend your wheels by prolonged sitting?
Is it possible to bend your wheels by prolonged sitting? by Kitskaboodle
Started on: 11-06-2021 10:10 PM
Replies: 10 (476 views)
Last post by: 30+mpg on 11-26-2021 03:26 PM
Kitskaboodle
Report this Post11-06-2021 10:10 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know it’s an odd question to ask but sometimes I really worry about letting my 86 GT sit in the garage for extended periods. To be honest, I’m trying to keep it “mint”. That means it sits a lot (up to a year sometimes) but I do notice that after a long time sitting the tires do bulge out a little bit. (yes, I know this is probably an air pressure issue)
Anyways, I sometimes wonder if it’s possible to get a bent / tweaked wheel from sitting for such a long time? I am aware that you can get flat spots on a radial tire from sitting but my question is specifically about the wheels themselves.
Your thoughts? Kit
cvxjet
Report this Post11-06-2021 10:26 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
You won't have any affect on the Wheels...But the tires; Put the car on stands during prolonged sitting.
Report this Post11-06-2021 11:23 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might have a problem with spoke wheels. One of my brothers-in-law had an MGB GT that he left at a friend's house when he moved several states away. When he retrieved the car, he had to have the spoke wheels re-tuned by adjusting the spokes. They had lost their symmetry.
Report this Post11-06-2021 11:46 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Termites might be more of a concern.
[This message has been edited by Patrick (edited 11-26-2021).]
R Runner
Total ratings: 98
Report this Post11-07-2021 02:49 AM Click Here to See the Profile for R RunnerSend a Private Message to R RunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a car that I store, but to keep the tires semi-usable, the car is jacked up off the ground. I built a wood support for all 4 corners and put 8 casters on each allow movement around the shop as needed.
hyperv6
Total ratings: 93
Report this Post11-07-2021 11:54 AM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
No wheels will not bend from sitting,
Tires will flat spot from sitting. Some times when they warm they will go back but too often older tires will take a set and remain flat in one spot.
Race Ramps make tire cradles that prevent damage to the tires. They are very effective.
I am not a fan of jacking a car up. One if you let the suspension hang it can damage shocks and struts. Also if it is off the ground should you need to move it fast like in a case of fire or the like it is no t going to happen.
Performance tires are softer compound and often victims of flat spots. My old Comp TA Radials used to clear up but as the rubber got older and harder the flat spots remained.
You can also top off the air pressure and roll the car a bit once a month so move the pressure point.
Report this Post11-22-2021 07:15 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
My Fieros sit inside about 6 months out of the year in a garage. So far no problems but every now and then I push the car a few inches to change the spot on the tire where the car sits. Not ideal but its been working.
Australian
Report this Post11-26-2021 04:23 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Earthquakes will bend your rims. Sitting would likely dig rims into surface air loss would likely be from old stems rather than warped wheel.
hyperv6
Total ratings: 93
Report this Post11-26-2021 07:56 AM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Air loss is most common to the bead seals on many wheels. Hard rubber and imperfect surfaces can leak air. Also temp changes will decrease air pressure in colder areas.
Valve stems may leak but beads are most common.
Skybax
Total ratings: 78
Report this Post11-26-2021 11:32 AM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's what I do, easy and effective.
30+mpg
Total ratings: 97
Report this Post11-26-2021 03:26 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
By driving the car more, worries disappear.
Fieros are designed to be driven, not stored.
