  First time seeing a junkyard Fiero that had an engine swap
First time seeing a junkyard Fiero that had an engine swap by reinhart
Started on: 11-05-2021 07:36 AM
Replies: 14 (609 views)
Last post by: reinhart on 11-22-2021 04:52 AM
reinhart
Report this Post11-05-2021 07:36 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Saw an 86 GT with a 3800 engine in the local junkyard today.
ace5514
Report this Post11-05-2021 08:11 PM Click Here to See the Profile for ace5514Send a Private Message to ace5514Edit/Delete MessageReply w/QuoteDirect Link to This Post
Please tell me you took parts off the car...like the computer and harness ect. you could sell or use that stuff.
Notorio
Report this Post11-06-2021 10:13 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was this an approved swap with a CARB sticker? Was it a clean swap?
reinhart
Report this Post11-09-2021 05:09 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took nothing off the engine and didn't see a CARB sticker. There's nothing special about a "Fiero 3800" engine in a junkyard. It's the same engine two cars over in a Celebrity or Grand Prix. Perhaps something like an engine mount would be useful if you want to spend 2 hours on your back to get a $50 part that the yard will sell you for $15.
Notorio
Report this Post11-09-2021 01:09 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was just wondering ... it seems like a lot of effort goes into working with a BAR ref to do a swap with the emission parts, etc., so the car will be certified and that such a car would not end up in a yard. Perhaps this was a non-compliant swap whose luck ran out?
cam-a-lot
Total ratings: 99
Report this Post11-11-2021 08:00 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Funniest reply of the Day! Loved it
css9450
Total ratings: 87
Report this Post11-11-2021 08:27 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
I did too! I want to see pics of the 3800 Celebrity!
longjonsilver
Report this Post11-12-2021 05:47 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
It had to have had the passkey system deactivated, probably a delete for the downstream cat and if a manual then other things deleted off the computer. The computer would be worth money, as would the custom brackets.
jon
I'm the original owner of a white ' 84 2M4 purchased Dec 10, 1983 from Pontiac. Always garaged, no rust, 3800SC, 4-wheel drifts are fun!
reinhart
Report this Post11-13-2021 12:56 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
jon
I was an automatic. The computer is the same computer as a non-Fiero 3800, no? If you're saying the chip was custom., I'd believe that. I don't think the custom chip would be worth much though. Maybe I'm wrong.
Total ratings: 328
Report this Post11-13-2021 10:10 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are many items needed for a 3800 Fiero engine swap. Mounts/Brackets, alternator relocation bracket, custom belt tensioner, fuel and water lines, swap harness, throttle cable bracket and reflashed PCM. If you salvaged all of them you'd probably have $700 worth of parts, (provided they are well done) in excellent shape and working. You also have a supercharger, fuel rail, and LIM there worth a couple hundred used and an exhaust system worth a few bucks. Great find for someone doing that swap.
87_special
Report this Post11-18-2021 01:43 PM Click Here to See the Profile for 87_specialSend a Private Message to 87_specialEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where in OC is the junkyard? Can you give us the address or business name?
reinhart
Report this Post11-18-2021 04:02 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's one of the pick your parts. The one in Sante Fe.
87_special
Report this Post11-18-2021 08:45 PM Click Here to See the Profile for 87_specialSend a Private Message to 87_specialEdit/Delete MessageReply w/QuoteDirect Link to This Post
I see it but the decklid is closed and there's no picture of the engine. Did it have the supercharger or n/a? I wonder if it's worth the 2+ hour drive. I want all the swap parts...
NIT WIT
Report this Post11-18-2021 08:49 PM Click Here to See the Profile for NIT WITSend a Private Message to NIT WITEdit/Delete MessageReply w/QuoteDirect Link to This Post
Definitely go back and get the passenger side axle
I’m dealing with that nightmare lol
reinhart
Report this Post11-22-2021 04:52 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
N/A
