  Brake booster filter
Brake booster filter by hunter29
Started on: 04-12-2021 09:30 PM
Replies: 8 (455 views)
Last post by: Dennis LaGrua on 04-21-2021 10:17 PM
hunter29
Report this Post04-12-2021 09:30 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, so I dug up the old thread from 2006, now fifteen years later what are you guys doing to replace this filter, can I still get one? from who? Been looking , no luck so far..thanks
Mike in Sydney
Report this Post04-13-2021 12:20 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Summit Racing have them. Look for Brake Booster Check Valves. I've got a Raybestos CV89000 - Raybestos PG Plus Professional Grade Power Brake Booster Check Valves
Mike in Sydney
Report this Post04-13-2021 12:22 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mike in Sydney
Member since Sep 2011
deleted duplicate post
[This message has been edited by Mike in Sydney (edited 04-13-2021).]
hunter29
Report this Post04-13-2021 10:16 AM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you, but I don't need the check valve I'm looking for the filter..
dremu
Report this Post04-13-2021 11:12 AM Click Here to See the Profile for dremuSend a Private Message to dremuEdit/Delete MessageReply w/QuoteDirect Link to This Post
IIRC, it was only on early cars ... do you mean this?
https://www.dormanproducts.com/p-4019-80195.aspx
Autozone shows them as available but OReilly doesn't, so they may be unobtanium at this point ..shrug..
-- A
Report this Post04-13-2021 01:02 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
84-86 Booster Filter is in Engine Bay on Front wall next to Wire Hardness passthru.
Pull out filter and see if air moves easy. If plugged then bypass w/ metal tube.
Before connected this way....
Disconnect booster check valve, and use compress air to clear the pipe going thru the cabin. A lot of crap can sit there for years, get loose and suck by the engine.
I'm not sure if OE filter can be cleaned. I don't have one to take apart to see how it's made or could clean w/o doing more damage.
⚠️ Why Bypass? After market filters are Plastic cases and have problems next to the exhaust.
87+ doesn't have the filter.
Booster pipe is also Bigger then others and uses booster check valve to fit bigger hose.
hunter29
Report this Post04-13-2021 06:14 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
-- A
Thanks, Don't know yet, haven't gone looking for it yet..
hunter29
Report this Post04-13-2021 06:18 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
hunter29
Member since Feb 2020
Thanks, I'll check it out and see.. Why can we make own own... or retrofit something used for another purpose.
I have a friend who is a maintenance guy at an auto plant, I'll ask him if he uses anything like this filter.
Total ratings: 328
Report this Post04-21-2021 10:17 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The filter was eliminated after 1985 so replacing it with a straight tube should be OK.
