Thank you for the add to the forum! I've been lurking and getting information from the group for over a year and really appreciate the help.
After owning the car for 16 months it is running well and gets me back and forth to work (60 miles). It’s a 66,000-mile original GT that sat for around 12 years. The issue I’m having now is the Muncie 4-speed grinds when up-shifting to 3rd and 4th. Everything else with the transmission is fine. Below are the things I’ve done to remedy the situation.
1. Replaced clutch master cylinder (banjo facing up)
2. Rebuilt clutch slave cylinder
3. Adjusted cables using manufacturer specs
4. Steel clutch pedal
5. Drained/filled with recommended 5W-30
6. Drained/filled with Syncromesh
Could the synchros be out after only 66K?
Could the cables be stretched/worn?
Thanks in advance for WORTHWHILE suggestions.
1986 Fiero GT
Muncie 4-speed
2.8L V6
