  Whats the safest way to remove A and B pillar trim?
Whats the safest way to remove A and B pillar trim? by johnyrottin
Started on: 04-15-2019 06:10 PM
Replies: 4 (610 views)
Last post by: olejoedad on 04-16-2019 11:45 AM
johnyrottin
Total ratings: 85
Report this Post04-15-2019 06:10 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Time to reinforce the headliner board and do a new headliner. Its a perfect Beechwood interior so I want to keep the plastic tabs from being broken. Whats the best way to reface the pillar trims without breaking the tabs? Also, is there a "How To" on doing the resin reinforcement of the headliner board?
Fiero Thomas
Total ratings: 125
Report this Post04-15-2019 06:38 PM Click Here to See the Profile for Fiero ThomasSend a Private Message to Fiero ThomasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check out my thread this might help you
https://www.fiero.nl/forum/Forum9/HTML/000005.html
Larryinkc
Report this Post04-15-2019 09:14 PM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't offer any help with the trim removal, I broke a tab on one of mine.
I can help if one should get broken. The trim is ABS plastic and ABS pipe cement works great. I first used the ABS cement on the break to glue the tab back on, after it was dry I built up small fillets on the sides of the break area. I also used the ABS cement to glue one of the metal holders for the plastic clips on the windshield section on the A pillar trim. Mine has been removed twice since the repair and the repaired parts are still as strong as ever.
Larry
johnyrottin
Total ratings: 85
Report this Post04-16-2019 11:40 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys. I still can't really tell how the trim her the window releases. When i have the backer board out I would like to do the resin reinforcement of it. That way it should last forever(wish).
Total ratings: 207
Report this Post04-16-2019 11:45 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
After releasing the tabs along the top of the door, slide the a-pillar trim upwards to get it off of the plastic clips that anchor it to the windshield pillar.
Use a small screwdriver to carefully release the lever on the windshield pillar clips.
It is an art to remove them without breaking.....
