  Need a Shop
Need a Shop by Sudic
Started on: 10-23-2016 04:08 PM
Replies: 8 (319 views)
Last post by: Imnuts on 10-25-2016 09:18 AM
Sudic
Report this Post10-23-2016 04:08 PM Click Here to See the Profile for SudicSend a Private Message to SudicEdit/Delete MessageReply w/QuoteDirect Link to This Post
My problems keep stacking up and I don't have the time nor resources to fix them myself. I am looking for a shop near Dayton, OH and I want to know if anyone owns/ knows a good shop that will be able to get rid of my problems/ prevent some future problems. I am willing to travel pretty far for a good shop so if you know anyone please hook me up.
For reference, my known problems include:
-very little pressure in clutch
-major exhaust leak
-poorly routed vacuum lines
-not wanting to go all the way into some gears
-(probably more that I'm forgetting, plus whatever may break with time)
I wish I was able to do some of this myself, but college keeps me away from tools and a place to work (my lack of experience doesn't help either though)
Edit: I suppose it should be important to mention that I have about $1500 to get every little kink worked out.
[This message has been edited by Sudic (edited 10-24-2016).]
Total ratings: 466
Report this Post10-23-2016 04:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
What does that mean? Very little grip... or very little releasing?
J Gunsett
Total ratings: 50
Report this Post10-23-2016 04:55 PM Click Here to See the Profile for J GunsettClick Here to visit J Gunsett's HomePageSend a Private Message to J GunsettEdit/Delete MessageReply w/QuoteDirect Link to This Post
Send a PM to Oldjoedad and talk to him, He is out of Homer, MI.
Jack
Sage
Total ratings: 71
Report this Post10-23-2016 06:17 PM Click Here to See the Profile for SageSend a Private Message to SageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Might also try a note (PM) to 94blackbird.
He was doing work for Fiero people last year, and he is in Painsville.
Not sure of his schedule now, but worth a few minutes to find out.
HAGO!
Sudic
Report this Post10-23-2016 06:31 PM Click Here to See the Profile for SudicSend a Private Message to SudicEdit/Delete MessageReply w/QuoteDirect Link to This Post
The clutch isn't building enough pressure to release. I've tried bleeding it and still nothing. It's just enough to make the slave cylinder move a little bit.
Sudic
Report this Post10-24-2016 01:20 AM Click Here to See the Profile for SudicSend a Private Message to SudicEdit/Delete MessageReply w/QuoteDirect Link to This Post
Change of plans, I left my car at my parent's so that's in the Dayton, OH/ Richmond, IN type area. Edited the original post as well.
Imnuts
Report this Post10-24-2016 12:57 PM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I live in Dayton and I would probably take my car 200 miles if someone knew of a good Fiero shop. Best bet for clutch bleeding problems is to start out with Rodney Dickman's slave cylinder. http://rodneydickman.com/ca...cf5ba4f09fecf5c68b2d Not hard to install and can save many hours of head scratching. The one I just replaced was an aftermarket one that was only about 2 years old, so some of them can turn to crap very quickly.
It is possible that I could be persuaded to give you a hand with that problem. Of course at no charge and its not too cold out at the time. That's if you can trust someone that goes by Imnuts.
∇PONTIAC∇
“The difference between a Fiero owner
and genius is that genius has its limits.”
[This message has been edited by Imnuts (edited 10-24-2016).]
Sudic
Report this Post10-25-2016 12:01 AM Click Here to See the Profile for SudicSend a Private Message to SudicEdit/Delete MessageReply w/QuoteDirect Link to This Post
You know, if you have a good place to work and knowledge on Fieros, I'll treat you to lunch at least for that. But, if you truly feel up to help, I would greatly appreciate it.
[This message has been edited by Sudic (edited 10-25-2016).]
Imnuts
Report this Post10-25-2016 09:18 AM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just moved out of a house with a large 4 car heated garage and now my car is kept at a storage facility, so I do not have a place to work on cars. It will have to be done at your parents’ home or somewhere else. Actually a sloped driveway could be the ideal spot to bleed a clutch if the weather is nice.
I am on my 2nd Fiero, had my engine out 3 times and installed 3 new slave cylinders. This just means I am now just starting to know when a slave cylinder acts a certain way whether it need replaced or not and figured out my best way of bleeding the air out of it.
I live north of Dayton in Vandalia, hopefully close by and yes if we could find a convent time I can help. I will send you a private message with my phone #.
∇PONTIAC∇
