  Best tricks to remove musty (whatever it is) smells
Best tricks to remove musty (whatever it is) smells by 2.5
Started on: 05-26-2016 05:03 PM
Replies: 21 (496 views)
Last post by: Spoon on 06-04-2016 07:01 PM
Report this Post05-26-2016 05:03 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
What are your best tricks / methods to remove musty (whatever it is) smells from carpet, HVAC, etc?
Report this Post05-26-2016 06:52 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bruce
Report this Post05-26-2016 07:08 PM Click Here to See the Profile for BruceSend a Private Message to BruceEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I changed to the IGEE seat covers, I had to remove the seats to make installation possible. Since the seats were removed, I was able to scrub the carpets 2 - 3 times with Tuff Stuff. I also added a little Carpet Fresh, when the scrubbing was finished. That eliminated the much dreaded "Fiero Smell" ...for the time being, anyway.
bb
viperine
Report this Post05-26-2016 10:03 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's been my experience, that once the HVAC box has been cleaned of moldy debris (leaves, mice remains and their nests), that everything else smells better just by airing it out. The best results include thoroughly blowing out the debris packed in the A/C unit fins. A lot of work, but my 86 is very nice now. Dreading the process on my 87, which is next. And another source of smell is the insulation under the center console. Perhaps a good disinfectant spray to soak it with and air dry prior to reinstall.
bjc 350
Report this Post05-26-2016 11:59 PM Click Here to See the Profile for bjc 350Send a Private Message to bjc 350Edit/Delete MessageReply w/QuoteDirect Link to This Post
My 76 Corvette had been sitting a long time before I bought it. Mice and rats lived there. I had read somewhere that if you spread fresh coffee grounds over the carpet or floor and anywhere else, that would do the trick. In my case it worked better than expected. Cleaned it up with a shop vac after a week or so and the odors were gone. Never did smell bad again.
DKcustoms
Report this Post05-27-2016 12:30 AM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I bought my 88, it had a mix of smoke/musty/grosswhatever smell going on.
Took out the carpet, headliner, and seats and replaced them the same from my 86 that I had shampooed, the old Hoover house unit seemed to do the trick.
But for the HVAC, I turned the controls on to vent in outside air, the sprayed in Lysol in the hood intake area by the windshield, then I set the controls on RECIRC and let the lysol work its away around all the vents and settings.
Once it dried I took out the entire dash and cleaned all that I could to get out any debris/dust, etc.
Still smells fresh today
Report this Post05-27-2016 01:13 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now the inside of your car smells like a Starbucks!
Chris_narf
Report this Post05-27-2016 07:09 AM Click Here to See the Profile for Chris_narfSend a Private Message to Chris_narfEdit/Delete MessageReply w/QuoteDirect Link to This Post
Last time I had this issue with my 85, I completely stripped the interior down to the bare metal. I cleaned everything and then reassembled. However, if you're just looking for something to try that's really quick that doesn't require a lot of effort, I've had some success with a product called Ozium. Like some of the folks mentioned above, you'll want to have your system set on recirculate.
Link to Ozium on Amazon
-Chris
'85 V6 SE 4sp (SOLD)
'88 GT - Series 3 SC3800 w/ 3.5" pulley, 1.8" rockers, 3" exhaust, 3.5" intake, 3.29 gearing. Installed and tuned by Sinister Performance
'99 Kawasaki Vulcan 500, owned since new
'09 G37x Sedan w/ Premium & Nav (wife's car)
'13 G37xS Sedan (new daily driver)
'14 Yamaha FJR - 0-60 in 2.8s w/ 34MPG!!!
Report this Post05-27-2016 08:45 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I get a "new to me" Fiero, first thing is pulling the carpets and taking them to the carwash to be power washed. I normally hang them with the floor mat clamps on the wall of most wash bays. Then take them home and leave the carpets at and angle (so the excess water can run off) and in the sun for a couple of days to fully dry. Then reinstall.
While that is happening,
Let the seats and headliner sit in the sun and breeze for a couple of days.
Vacuum up all the cigarette ash in the console area in front of the shifter. If needed, wash that area down.
Pull the blower motor and pull whatever is in the HVAC duckwork.
That normally takes care of it on most cars.
TXOPIE
Report this Post05-27-2016 08:51 AM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
I do what Fieroguru does as well, but I do one extra step while cleaning the carpets.
You need to find a professional carpet cleaning company and see if they will sell you the industrial strength cleaner / deodorizer.
I purchased a gallon of the stuff a few years ago and nothing works quite like it.
I was in a clear gallon jug with no labeling on it
It is a yellow color...looks like urine after you after you have taken a bunch of multi-vitamins....sorry but that is what it looks like color wise.
[This message has been edited by TXOPIE (edited 05-27-2016).]
Report this Post05-27-2016 09:19 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
That's dangerous around a Fiero
Report this Post05-27-2016 09:20 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2007
bb
How long has it been?
Report this Post05-27-2016 09:21 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wow that's one sounds too easy to be true.
Report this Post05-27-2016 12:43 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Found another one, I'm doubting this one:
"Take a bunch of newspapers, crinkle the pages up and throw them into the car willy-nilly. Close the doors and let sit a day or two, and the newspapers will absorb the odor."
bjc 350
Report this Post05-27-2016 03:01 PM Click Here to See the Profile for bjc 350Send a Private Message to bjc 350Edit/Delete MessageReply w/QuoteDirect Link to This Post
The starbucks smell soon disipated. I can not remember where I read that idea. It may have been on this site. I did have to clean the ducting, but it wasn't too bad to do. The person I sold the car to did some additional refurbishment, and when he removed the door panels to see why the windows were slow, he found plenty of evidence of the mouse/rat inhabitants. That didn't seem to cause the smell to linger or I would have been in there myself. Seems the majority of odors are stored in the carpets, seats and maybe even the headliner. Shampoing and use of the vac helps a lot.
Report this Post05-27-2016 03:09 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I worked as a coffee roasterman back in the 80's. It was common knowledge back then to use ground coffee to absorb odors. Baking soda is used in the same manner.
[This message has been edited by Patrick (edited 05-27-2016).]
Gary W
Report this Post05-27-2016 03:17 PM Click Here to See the Profile for Gary WSend a Private Message to Gary WEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've had good results with activated charcoal (aquarium filter media). Sprinkle on carpet or pour it out in a pan if it's in a room that smells musty. Also good if you're going to store a car for a while. I know someone who swears by regular charcoal briquettes as well, crushed up. I haven't tried those, and wouldn't use any that had lighter fluid in them...
Report this Post05-27-2016 03:31 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Gary W:
... I know someone who swears by regular charcoal briquettes as well, crushed up. I haven't tried those, and wouldn't use any that had lighter fluid in them...
Ah yes, then Patricks flamethrower trick would work better tho!
Report this Post05-27-2016 03:55 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put another shrimp on the barbie!
Mickey_Moose
Total ratings: 145
Report this Post05-27-2016 04:01 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just use my ozone generator - kills and mold or mildew that you may have and eliminates smells .
That being said, do what fieroguru said - best way to clean the carpets.
[This message has been edited by Mickey_Moose (edited 06-07-2016).]
Gary W
Report this Post05-27-2016 04:17 PM Click Here to See the Profile for Gary WSend a Private Message to Gary WEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, yes... I've also heard that multiple open cans of Sterno do a great job... getting rid of the source of the odor.
Muahahahahahaha.
Spoon
Total ratings: 61
Report this Post06-04-2016 07:01 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ozone generators work great.
https://www.youtube.com/watch?v=D5fo0QnKgGY
https://ozonesupply.com/pro...aLb8hsp8waAj0q8P8HAQ
Spoon
[This message has been edited by Spoon (edited 06-04-2016).]
