  215/60/14 tires can't find has anyone tried 215/70/14
215/60/14 tires can't find has anyone tried 215/70/14 by AL
Started on: 07-03-2015 11:41 AM
Replies: 6 (263 views)
Last post by: MayhemWinters on 07-04-2015 12:59 PM
AL
Report this Post07-03-2015 11:41 AM Click Here to See the Profile for ALSend a Private Message to ALEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't seem to find tires,anyone tried a diff size for an 84 indy
Total ratings: 463
Report this Post07-03-2015 12:01 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
215/70s will be just as wide as 215 /60s, but substantially taller. I'd be more inclined to use 225/60s, if you can find them.
215 or 225 is the width of the "body" of the tire, in millimeters. 60 or 70 is the percentage of the height of that section, vs the width.
For example a 225/50-15 will be 225 mm wide, and the bottom of the wheel rim will be ~112.5 mm off the ground. (Nothing is exact, but that's a good ballpark explanation.)
To find equivalent tire sizes, go here...
http://www.rimsntires.com/specspro.jsp
If you plug your "old" and "new" tire sizes into the chart, it will tell you how they compare in all directions, as well as the resulting speedometer error.
88FieroGT TTops
Report this Post07-03-2015 12:50 PM Click Here to See the Profile for 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
last year I got tires for my GT--I used e-bay not for bid but for buy now I got all 4 (staggered too) for 240.00 just had to get someone to mount them
http://www.ebay.com/sch/i.h...%2F60%2F14+&_sacat=0
Pat Jones
IMSA GT
Total ratings: 250
Report this Post07-03-2015 01:03 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tire Rack still sells the BFGoodrich in that size:
http://www.tirerack.com/tir...num=16SR4RADTARWL2V2
However, I always use TireBuyer in the past with great success. They ship the tires to your local installer for you to have mounted on your car. Search by tire size, input your zip code at the bottom, and they will ship to any of your closest tire shops for free.
http://www.tirebuyer.com/
[This message has been edited by IMSA GT (edited 07-03-2015).]
Report this Post07-03-2015 05:00 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Summit has some
http://www.summitracing.com...ord=215%2F60%2F14%20
Americas Tire / Discount Tire has BFGs too
http://www.americastire.com...=14&y=11&x=36&cs=215
[This message has been edited by 2.5 (edited 07-03-2015).]
AL
Report this Post07-03-2015 06:33 PM Click Here to See the Profile for ALSend a Private Message to ALEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys I'll probably get the bfg s
MayhemWinters
Report this Post07-04-2015 12:59 PM Click Here to See the Profile for MayhemWintersSend a Private Message to MayhemWintersEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm currently running 215/70/14 on the rear, they are Toyo Extensa A/S, they go for $78 each on tread depot's website. They ship by way of UPS. They have excellent grip dry or wet and fill the wheel well nicely. I have no problem blasting around hairpin turns with them, and that's with the stock suspension on my 87 Notchie. I would run these tires instead of the BFG's any day. Also, I run 195/70/14 General Tires RT's up front that I got on Tire Rack, but I got those on closeout so at this time they are gone. However the General Tire RT 43 are available for $63.21 each now, and I believe they are even better than the regular RT's. The 195's up front definetly make turning at low speed, parking, and such easier. The previous owners 215's up front weren't bad though. ----That's just my 2 cents.
