  Cruise Control Failed!
Cruise Control Failed! by Cokeologist
Started on: 07-03-2015 07:46 AM
Replies: 4 (253 views)
Last post by: steve308 on 07-03-2015 09:33 AM
Cokeologist
Report this Post07-03-2015 07:46 AM Click Here to See the Profile for CokeologistSend a Private Message to CokeologistEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's Fiero Friday, so I drove my 85 2M6 SE to work this morning and on the way in the cruise control stopped working. It started to mildly accellerate and decellerate while on a flat stretch which I thought was odd, so I turned it off and back on and when I tried to set it again it wouldn't stick. If anyone can advise what needs to be replaced, where it is, and how difficult of a job it is I would be greatly appreciative.
Report this Post07-03-2015 08:01 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check the vacuum canister and the associated hoses first.
CoolBlue87GT
Total ratings: 150
Report this Post07-03-2015 08:17 AM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also check the brake & clutch switches, easy way to test those, while driving, with left foot, pull up on the clutch Pedal, try the crusie control, do the same for brake.
I had this problem on one of my Fiero's, if you find working after trying this, just adjust the switch. Good luck.
Rodney
Total ratings: 267
Report this Post07-03-2015 09:10 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it accelerates by itself it is probably the cruise servo unit. You can try taking it apart and try cleaning the one large steel rod plunger. That works occasionally.
If not get a new cruise servo.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
steve308
Total ratings: 58
Report this Post07-03-2015 09:33 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mine did the same - purchase a new cruise control switch (Dorman 1/3 the cost of AC Delco). Checked brake switch (I have an automatic) it was functional - checked all vacuum hose connections- all were good - checked the cable. Found the following page for info (www.michiganfieroclub.com/files/cruisecontrol) lots of good info and then I figured I'd try one more thing before I started to replace parts ---- I pulled cleaned and reinstalled the electrical connections on the servo and solenoid -- That was the problem and the cruise is working again.
[This message has been edited by steve308 (edited 07-03-2015).]
