  3800 Sc to 88 cradle
3800 Sc to 88 cradle by FieroFastBackL67
Started on: 05-15-2015 01:40 PM
Replies: 9 (435 views)
Last post by: FieroFastBackL67 on 05-16-2015 10:17 PM
FieroFastBackL67
Report this Post05-15-2015 01:40 PM Click Here to See the Profile for FieroFastBackL67Send a Private Message to FieroFastBackL67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is there anywhere I could buy a motor mount swap kit for 3800 Sc to 88 fiero cradle? I have everything needed to get started such as the 88 cradle, 5spd Getrag, L67 ect.. This would sure speed things up and avoid changing things later. I would like to just get it right the first time and have the motor and tranny sitting perfectly. Any pointers would be greatly appreciated! Thanks in Advance.
[This message has been edited by FieroFastBackL67 (edited 05-16-2015).]
Report this Post05-15-2015 03:09 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mount the tranny on stock mounts.
Attach the engine.
Level the unit and set square to cradle.
Fabricate two engine mounts, one to front cradle cross member, the other to the rear corner of cradle.
nosrac
Total ratings: 50
Report this Post05-15-2015 04:21 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by FieroFastBackL67:
Is there anywhere I could buy a motor mount swap kit for 3800 Sc to 88 fiero cradle? I have everything needed to get started such as the 88 cradle, 5spd Getrag, L67 act.. This would sure speed things up and avoid changing things later. I would like to just get it right the first time and have the motor and tranny sitting perfectly. Any pointers would be greatly appreciated! Thanks in Advance.
Fierorog on this forum for engine bracket.
Rodney Dickman for poly replacements mounts. Stock Fiero rubber mounts are not recommended.
FieroFastBackL67
Report this Post05-15-2015 05:33 PM Click Here to See the Profile for FieroFastBackL67Send a Private Message to FieroFastBackL67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you guys I'll see what I can do with this info.
Report this Post05-15-2015 06:28 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
As nosrac stated, don't use the stock mounts, they are only good for mock-up. All mounts should be poly.
FieroFastBackL67
Report this Post05-16-2015 12:44 AM Click Here to See the Profile for FieroFastBackL67Send a Private Message to FieroFastBackL67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Polyurethane is the way to go. I'll be put that on everything.
IwannaIRM
Total ratings: 58
Report this Post05-16-2015 02:38 PM Click Here to See the Profile for IwannaIRMSend a Private Message to IwannaIRMEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am producing brand-x mounts...should be available in about 2 weeks.
FieroFastBackL67
Report this Post05-16-2015 05:14 PM Click Here to See the Profile for FieroFastBackL67Send a Private Message to FieroFastBackL67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does your poly mount bolt up with Fierorog 3800 SC engine bracket for the 88 cradle?
IwannaIRM
Total ratings: 58
Report this Post05-16-2015 08:37 PM Click Here to See the Profile for IwannaIRMSend a Private Message to IwannaIRMEdit/Delete MessageReply w/QuoteDirect Link to This Post
All my mounts are poly and are a different design from Fierorog's. The Brand-X mounts are a proven set of mounts that have been around for years and have been installed time and time again. I bought the business, original prototypes, fabrication jigs, etc. from FieroX (Ryan).
I can't say my mounts work with Fierorog's mounts because I don't know anyone who has mixed the two sets together.
I'd be happy to provide you with my full set of mounts when they are ready but if you choose to go with Fierorog it is your decision.
Either way, wish you good luck on your build and I can't wait to see another 3800 on the road.
FieroFastBackL67
Report this Post05-16-2015 10:17 PM Click Here to See the Profile for FieroFastBackL67Send a Private Message to FieroFastBackL67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Your mounts are with the bracket and the poly together? PM me the prices and what I need thanks.
