Update System
  Took to the printer, Here's what came of it
by gingerRT
Started on: 04-27-2015 09:03 AM
Replies: 15 (645 views)
Last post by: tom10122 on 04-29-2015 09:38 AM
gingerRT
Report this Post Click Here to See the Profile for gingerRTClick Here to Email gingerRTSend a Private Message to gingerRTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Both are first prototypes. The speaker adapter isn't to correct scale. The radio bezel has the HVAC opening enlarged to incorporate a different HVAC. Next design is to have a Double Din Radio opening. You would be able to reuse your current HVAC vents. Then it would be up to you to finish how you want it with paint or an overlay.
Switch plate would be used for incorporating switches and making it look factory. I'm planning on using Grand Prix switches and making the plate resemble a close to factory look.
jmbishop
Total ratings: 165
Report this Post Click Here to See the Profile for jmbishopClick Here to Email jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
what hvac controls are you using?
Tony Kania
Total ratings: 305
Report this Post Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool project.
gingerRT
I'd like to incorporate an HVAC setup from a 94-96 Roadmaster. I haven't checked if it would fit with the skeleton though. Just wanted to see if I could get a good print for the radio bezel and so far it seems like it would work. I need to print a double din for my brother's car next.
DKcustoms
Report this Post Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would we be able to get a Double Din radio opening with the stock HVAC controls?
gingerRT
Yeah, that's no problem at all!
mmeyer86gt/gtp
Total ratings: 73
Report this Post Click Here to See the Profile for mmeyer86gt/gtpClick Here to Email mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could you do a print where the face plate is integrated into the surround where to attract you just use the 3 screws on the bottom? What is the size up an print. Might look into printing the cover that goes over the Odin connector/ cigarette lighter they always break
jmbishop
Total ratings: 165
https://www.fiero.nl/forum/Forum1/HTML/094971.html
The fiero uses a cable to operate the blend door, the roadmaster and most other cars are electronic.
http://www.ebay.com/itm/HVA...em2edc05cd13&vxp=mtr
you'd need to figure out the wiring and use something like this
[This message has been edited by jmbishop (edited 04-27-2015).]
gingerRT
Thanks, but I'm well aware that it isn't a direct swap. I would have to add a blend door motor. I've seen other writeups on using a GM digital HVAC in place of a cable HVAC setup. Wiring isn't a problem and I can print any bracket I would need
Total ratings: 182
Report this Post Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Very cool!
Carcenomy
Report this Post Click Here to See the Profile for CarcenomyClick Here to visit Carcenomy's HomePageSend a Private Message to CarcenomyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Roadmaster digital HVAC you say?
You officially have my attention
Carcenomy
Roadmaster wiring diagram... http://www.goldsswagon.com/...admaster_auto_ac.pdf
Looks reasonably achievable too. Hmmm, would look damn nice with that Cavalier digital cluster I bought recently too...
Fiero Vampire
Report this Post Click Here to See the Profile for Fiero VampireSend a Private Message to Fiero VampireEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's really cool, never used a 3D Printer yet so I have to ask if you were to guess how much is the materials to print that? and can you print with different types of plastic?
tom10122
Report this Post Click Here to See the Profile for tom10122Click Here to Email tom10122Send a Private Message to tom10122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cool are you going to release the files or just keep them in house?
gingerRT
I'll plan to keep them in house until I get a good working swap, then I'll release them.
tom10122
AWESOME, I appreciate it.
