  Bought myself an early xmas present
Bought myself an early xmas present by bonaduce
Started on: 12-18-2014 05:52 PM
Replies: 10 (682 views)
Last post by: Raydar on 12-20-2014 01:05 PM
bonaduce
Report this Post12-18-2014 05:52 PM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, after almost 20 years after my first fiero, I have made the jump to an 86 GT. Picked it up out of PA on Tuesday, and hope to get some work done on it over the weekend before put into storage for the winter. So far things that I can see that need attention, coolant leak at the right rear, looks like hose going into waterpump. Oil leak, small, undetermined yet. Both headlight motors need to be rebuilt. Want to adjust throttle cable, seems a tad loose, and a tune up. Overall I am very pleased with the purchase. Hopefully pip is working.
I was happy to get it up in the air and see no rust underneath.
dan
mrfred8
Report this Post12-18-2014 05:54 PM Click Here to See the Profile for mrfred8Click Here to visit mrfred8's HomePageSend a Private Message to mrfred8Edit/Delete MessageReply w/QuoteDirect Link to This Post
That gold paint looks great. Don't find too many not faded out. Congrats!
TXOPIE
Report this Post12-18-2014 06:19 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very Nice! I like the burl wood grain with the interior.
FieroMaster88
Total ratings: 168
Report this Post12-18-2014 06:59 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like a solid car! Congrats.
88 Coupe: 2.0L Turbo 4 Cylinder, W2A, T25 Turbo, water/meth injection
84 Indy #64: Restoration Project, Super Duty 4 swap
zzzhuh
Report this Post12-18-2014 07:03 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice! Any fiero bought with a good paint job is always a good deal.
I have an 86 GT in silver that has an issue with the driver side headlight, it's a pretty common issue. Your coolant leak could be as simple as tightening a hose. I had the same issue (except it was on the passenger side)
https://www.fiero.nl/forum/Forum2/HTML/134240.html
At first I thought you lived in Johnstown CO, you had me all excited.
tshark
Report this Post12-18-2014 08:53 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice! Reminds me a bit of a previous Fiero I had.
bonaduce
Report this Post12-19-2014 09:01 AM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Confirmed coolant leak this morning as being the waterpump, as all other fieros have been 4 cylinders to me, any hints. Looks like just unbolt and move forward and up, reverse for installation.
dan
bonaduce
Report this Post12-19-2014 09:09 AM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
bonaduce
Member since Oct 2002
thanks guys, was debating on getting another one or continue to work on the DOHC swap, decided I wanted a stock car to drive. So the swapped one will be going bye bye.
dan
1MohrFiero
Total ratings: 157
Report this Post12-20-2014 08:29 AM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Truthfully, I believe it works better to just drop the engine to change the water pump. Those 3 little bolts under the pulley are too easy to strip. Also check closely around that leak, the water passage through the timing cover can masquerade as a water pump leak. Good luck.
fierobug
Report this Post12-20-2014 08:36 AM Click Here to See the Profile for fierobugSend a Private Message to fierobugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome! Nice clean car. Have fun and Merry Christmas. Jeewhiz what a christmas present!
FIEROBUG!!!!!!!!!!
Total ratings: 463
Report this Post12-20-2014 01:05 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice!!!
You can replace the water pump through the wheel well, but it's a pain in the posterior.
Make sure that's where the leak is. (There IS a weep hole in the housing.)
I have seen leaks from the timing cover, too. There is a thin piece of gasket between the timing cover and the block, right next to where the coolant hose attaches. If it's not sealed well in that area, it can leak.
Or it could just be a loose hose clamp at the top of that hose.
It's easy to see with the car on a lift.
