| | | quote | Originally posted by MstangsBware:
O...Electrical gremlins suck and AC issue isnt far behind. Whats it doing or not doing? |
Electrically, it tries to restart itself after turning off and it's way over charging the battery. Had to have the battery jumped and there was enough reverse charge it melted AAA's heavy duty jumper cables.
It appears I have both a starter and alternator problem but beyond that I don't know what's up. When it's running it holds proper voltage, idles properly and glows the exhaust manifolds...the last item will be resolved, taking it in to remove/delete the cat and the rattling muffler with a new Spintech muffler and C6 resonator tips...as for the A/C problem I don't know where to start. Had dye put in the system and no leaks were found, compressor clutch engages and fan kicks on but cold air after recharge lasts only about a week. So, there's a leak somewhere in the system...but where?
