  coolant hoses
coolant hoses by jim94
Started on: 01-08-2014 09:24 PM
Replies: 9 (445 views)
Last post by: 2.5 on 06-08-2015 08:25 AM
jim94
Report this Post01-08-2014 09:24 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
My 87 GT still has the original hoses on it. Who still has the original on there car. How do you know when to replace them?
sco77
Report this Post01-09-2014 10:04 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mine might be original.
I don't think there is a way to know if a hose NEEDS to be replaced without inspecting the entire hose (inside included), it's something that is replaced as preventive maintenance, especially the top hose which is more likely to fail. Definitely should be replaced.
86 Fiero GT 4spd - L67 swap: VS cam, GenV
98 GTP - Some mods
Report this Post06-02-2015 11:42 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Our 86 Coupe with 2.5 and 88 Formula (2.8) both have original hoses.
I am sort of scouting where to get replacements for all the hoses.
Is there a part number list anyone has put together?
I especially dont want to have it all drained / put back together and find out I am missing one hose, or have a one wrong hose...
Report this Post06-02-2015 01:21 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would be worried that the new hoses may be inferior. There are a lot of new parts like that.....shop carefully.
Report this Post06-02-2015 04:09 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I figured coolant and heater hoses are one thing that should be replaced before they fail but for sure I know what you mean.
Jason88Notchie
Report this Post06-02-2015 04:37 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
The hoses near the where it connects will usually start to bulge and feel softer than the rest of the hose.
88cryan
Report this Post06-06-2015 01:49 AM Click Here to See the Profile for 88cryanSend a Private Message to 88cryanEdit/Delete MessageReply w/QuoteDirect Link to This Post
All the hoses on my 88 GT were original but I wanted maximum reliability so I replaced all of them. I didn't make a list of all the part numbers, but I can tell you they are hard to find. Autozone only has three of the five primary cooling hoses.
EDIT: Deleted misinformation about lower coolant hose on passanger side. I didn't know Rodney has them too.
[This message has been edited by 88cryan (edited 06-06-2015).]
Rodney
Total ratings: 267
Report this Post06-06-2015 06:36 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have all the 88 V-6 coolant hoses on hand:
http://rodneydickman.com/ca...h=22&products_id=344
Heater core with A/C:
http://rodneydickman.com/ca...h=22&products_id=319
I do not stock the non A/C heater core hoses because they are readily available elsewhere.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
Shho13
Report this Post06-06-2015 09:47 AM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney you are the man!!! Ill keep this in mind and probably order a set just to have on hand just in case.
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
Report this Post06-08-2015 08:25 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Rodney! Will you be at Fierorama?
