  Another rant
Another rant by JMergen
Started on: 08-25-2013 12:57 PM
Replies: 9 (504 views)
Last post by: JMergen on 08-26-2013 10:56 PM
JMergen
Report this Post08-25-2013 12:57 PM Click Here to See the Profile for JMergenSend a Private Message to JMergenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Love this car, but starting to have bad hesitation on take off.
Check forum, pull codes, replace TPS. No improvement.
Check forum, pull codes, replace MAP sensor. Running worse.
Check forum, pull codes, replace MAT sensor. Barely runs.
Check forum, to hell with codes, replace temp sensor. No improvement.
Check forum, replace IAC. No improvement. Beginning to wonder about this car.
Check forum, check EGR. Its OK
Check forum, replace oil pressure switch. Car beginning to pi$$ me off.
Check forum, try to set timing, but jumping all over the place. Replace timing chain and water pump. Car only runs a minuet then dies.
Check forum, check fuel pressure relay. Its OK . I HATE this car.
Check forum, replace ECM, Will not even start. Ready to push this SOB into street and write "FREE CAR" on windshield.
Check forum, replace fuel pump....Runs like a champ!!!
I love this car.
Carver1
Total ratings: 62
Report this Post08-25-2013 01:42 PM Click Here to See the Profile for Carver1Send a Private Message to Carver1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fuel, air, spark.
The big three!!
84 Fiero V6 4 speed
11 Camaro SS/RS LS3 6.2
13 Traverse LS 3.6
12 Silverado Z71 5.3
12 Tahoe LT 5.3
64 Lincoln Continental 7.0
RCR
Total ratings: 102
Report this Post08-25-2013 08:58 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
vacuum leak
Bob
Macs86GT
Report this Post08-25-2013 09:00 PM Click Here to See the Profile for Macs86GTSend a Private Message to Macs86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
have you checked the coil, and the icm, and the general condition of the distributor, cap, rotor wires?
SuperchargedV6
Total ratings: 174
Report this Post08-25-2013 09:59 PM Click Here to See the Profile for SuperchargedV6Send a Private Message to SuperchargedV6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Had issues and turned out to be the pump also. Drive down the highway and th ecar would shut off after it got super hot. Once the pump totally failed I figured it out and it doenst get hot anymore. No lean fuel mix. I think these new fuels kill our old pumps. Rick B
dobey
Total ratings: 371
Report this Post08-26-2013 03:04 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by RCR:
vacuum leak
Bob
stress cracks
CowsPatoot
Total ratings: 84
Report this Post08-26-2013 06:18 PM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been there...done that...got the T-shirt. Congrats on getting it fixed.
Heartland Fiero
Report this Post08-26-2013 07:38 PM Click Here to See the Profile for Heartland FieroSend a Private Message to Heartland FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by JMergen:
I love this car.
Life is too short to waste time hating the Fiero.
I'm glad to hear there was happy ending.
n7vrz
Report this Post08-26-2013 09:46 PM Click Here to See the Profile for n7vrzSend a Private Message to n7vrzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by SuperchargedV6: I think these new fuels kill our old pumps. Rick B
The alcohol in the new fuels does not play well with old/original fuel pumps on our cars. The seals swell up and can stop the pump from running once you stop and then try to restart the car. Ask me how I know.
If I let it sit for about an hour then I could restart the car and drive. But as soon as I shut it off again.................
JMergen
Report this Post08-26-2013 10:56 PM Click Here to See the Profile for JMergenSend a Private Message to JMergenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks.
JM
