  ground effects interchangable?
ground effects interchangable? by adm927
Started on: 09-07-2016 01:27 PM
Replies: 6 (293 views)
Last post by: Australian on 09-18-2016 01:30 AM
adm927
Report this Post09-07-2016 01:27 PM Click Here to See the Profile for adm927Send a Private Message to adm927Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are the ground effects the same between the gt and the notch back bodies? I am looking at an 87 gt with broken ground effects on the drivers side but the owner has an 85 notch back with what appears to be the same ground effects. will they fit?
Report this Post09-07-2016 01:30 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you referring to the rocker panels? If so, all aero rockers are the same.
[This message has been edited by Patrick (edited 09-07-2016).]
adm927
Report this Post09-07-2016 01:38 PM Click Here to See the Profile for adm927Send a Private Message to adm927Edit/Delete MessageReply w/QuoteDirect Link to This Post
yes the rockers. You say aero do you mean fast back design? If so then the notch back type will not fit?
Report this Post09-07-2016 01:43 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are we talking about the roof... or about the aero trim?
Fastbacks and notchies can both have aero trim. Aero rocker panels are all the same.
adm927
Report this Post09-07-2016 02:39 PM Click Here to See the Profile for adm927Send a Private Message to adm927Edit/Delete MessageReply w/QuoteDirect Link to This Post
ahh yes that is what I wanted to know. So the aero trim on the rocker panels is all the same. Thanks!
jaskispyder
Total ratings: 205
Report this Post09-07-2016 02:44 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
That would be an 85GT... and yes, it will fit. 85GT, 86SE, 87SE (and 84 Indy) were called aero-trimmed. The fastback also used aero trim.
Australian
Report this Post09-18-2016 01:30 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anything with a straight line can be used for the ground effects. So plenty of other cars could be used. Mine are custom from GTO
