  Wheel question
Wheel question by Buck531
Started on: 08-24-2016 08:58 AM
Replies: 13 (344 views)
Last post by: Fastfiero1 on 08-25-2016 08:51 AM
Buck531
Report this Post08-24-2016 08:58 AM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
I bought a set of Cavalier Z24 wheels a few months ago. Put some tires on them and they seem ok. However the wheel is only a 6" wide rim so that limits what size tire I can put on them. I was looking at Craigslist a few minutes ago and found these.
http://columbus.craigslist.org/wto/5746961142.html
I also noticed with the cavalier wheels the back seems to sit in the wheel well further than I'd like. Would these fill out the wheel well better? I was thinking of putting 225/50 or 55's.
03 Buick Regal. 13.0x @103
87 Fiero GT. L67 swap soon
Buck531
Report this Post08-24-2016 09:05 AM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
What it looks like now with the Cavalier wheels.
Tires are 205/55/16.
Total ratings: 463
Report this Post08-24-2016 11:47 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've run these 1" hubcentric spacers on the back of my '84 duke, and then on my '88 Formula, for the last five years. They bring my Sunfire wheels (same offset and width as the Cavalier wheels) out to the edge of the rear fenders (instead of being tucked in too far).
No loosening of lug nuts has occurred after being torqued down properly, and no added vibration at high speed
205/55/16 tires on the front, 225/50/16 on the back.
[This message has been edited by Patrick (edited 08-24-2016).]
jaskispyder
Total ratings: 205
Report this Post08-24-2016 11:52 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
The offset is different. You have to be careful that wide tires don't rub on the rear strut, as the rim may be very close to the strut already. A solution is to use a spacer, as mentioned. I would do this instead of trying to use tires to make them stick out more.
Buck531
Report this Post08-24-2016 11:59 AM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
What I want to do is be able to run a wider tire after I do the swap. I doubt the 205/50's will have much grip. This is why i wanted to go to a 7" wide rims so I can stick a beefier tire on it.
I could get the spacer which isn't a bad idea but I'm not sure how wide of a tire I can stuff on a 6" wide rim. I've googled and the cavy peeps are running 225/50/ on the same wheels.
Buck531
Report this Post08-24-2016 12:06 PM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
Buck531
Member since Mar 2016
Also, the offset on the CL wheels are 35 MM. It looks like a stock Cavy wheel is 45-47 MM.
Fiero_Adam
Report this Post08-24-2016 02:23 PM Click Here to See the Profile for Fiero_AdamSend a Private Message to Fiero_AdamEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've used 16x7, 38 offset, with 225 50 tires before without issue. The tires are close to the struts in the rear but I had no problems. The wheels you're looking at on craigslist should be fine. I wouldn't use a 225 on your current wheels, though.
Buck531
Report this Post08-24-2016 02:37 PM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah I knew 225 would be way too wide for a 6" wheel and that's why I was looking at these with a 7".
Would I still need a spacer to pull the wheel out closer to the wheel well with the ones on CL or will these work ok?
Report this Post08-24-2016 03:32 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.autoanything.com...vs-wheel-backspacing
Sometimes when talking about offset and backspacing the terms get intermixed with eachother.
"Offset is the distance from the center of a wheel to its mounting face"
"Backspace is the distance from the inside edge of a wheel to the mounting face."
[This message has been edited by 2.5 (edited 08-24-2016).]
Report this Post08-24-2016 03:39 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2007
10 more Mm of positive offset?
It seems this would be only 3/8 of an inch different.
Then depending on where the rim is wider the extra rim width would come into play.
rogergarrison
Total ratings: 551
Report this Post08-24-2016 05:17 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Simple rule for tires is the tire tread should be close to the width of the rim. You cant put an 8"-10" wide tire on a 6" rim. You need an 8"or 10" rim. If not it will wear fast and funny, handle terrible and be lucky if it dont pop off the rim in a corner.
Buck531
Report this Post08-24-2016 06:52 PM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have any pics of your wheels/tires?
Fiero_Adam
Report this Post08-25-2016 01:06 AM Click Here to See the Profile for Fiero_AdamSend a Private Message to Fiero_AdamEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't have those anymore, but they looked fine. 35 offset works well on the Fiero. In fact, I believe the factory 15" GT wheels are 35 offset, maybe 30 which isn't much of a difference. They're about even with the fenders.
Fastfiero1
Report this Post08-25-2016 08:51 AM Click Here to See the Profile for Fastfiero1Send a Private Message to Fastfiero1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here is the Fiero wheel info chart I found here a while back. I use this often when planning and helping others.
I don't remember who put this together but they deserve some major Kudos
Fiero's Owned:
1987 Coupe 2.5 5spd May 99 - June 03
1987 GT V6 5spd July 30 2012 - Current
