  lowering seats
lowering seats by mmeyer86gt/gtp
Started on: 01-17-2019 10:10 AM
Replies: 16 (1138 views)
Last post by: theogre on 04-26-2021 10:33 AM
mmeyer86gt/gtp
Total ratings: 73
Report this Post01-17-2019 10:10 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would like to lower my seats or find a way to lower them. I know archie used to do it but dont think he does that type of work anymore. Any other ideas?
Report this Post01-17-2019 10:28 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I know a few who have gone no rails / non adjustable.
hnthomps
Total ratings: 50
Report this Post01-17-2019 11:48 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some of the kit cars use a lowered floor pan to create more headroom with a specific seat.
Nelson
mmeyer86gt/gtp
Total ratings: 73
Report this Post01-17-2019 02:44 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
im good with the no rails just need to know how you would do it
KissMySSFiero
Total ratings: 111
Report this Post01-18-2019 11:52 AM Click Here to See the Profile for KissMySSFieroSend a Private Message to KissMySSFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just did this a week or so back. I’ll get some pics and post them.
If you don’t see them, PM me.
Basically what I did was flatten the bent part of the rail and redrilled
The mounting holes. Took about 30 minutes and I gained close to an inch.
I did it for some rx7 seats I installed. The wheel was touching my legs at the tilt I like.
After, it was back to normal.
I’ll be doing the same mod for my chop with fiero seats.
SSFiero@Aol.com
mmeyer86gt/gtp
Total ratings: 73
Report this Post01-18-2019 02:09 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
PICS would be awesome definitely need a little more headroom with my jimmy seats. they are awesome seats but sit about an inch higher than the fiero as they have spring going across the bottom in the middle and i can get new foam for them.
mmeyer86gt/gtp
Total ratings: 73
Report this Post01-24-2019 11:49 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
bumpo
Report this Post01-24-2019 01:47 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
These pictures were from the stinger build thread. I added the red circles and comments.
Spadesluck
Report this Post01-25-2019 04:11 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone done this with the stock seats by chance? I tried doing a search and came up empty handed.
KissMySSFiero
Total ratings: 111
Report this Post01-25-2019 08:08 PM Click Here to See the Profile for KissMySSFieroSend a Private Message to KissMySSFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. That’s how Archie did it in his choptops
SSFiero@Aol.com
Report this Post01-25-2019 08:49 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The rails above were part of the Stinger build thread and it has stock fiero seats with upgraded covers.
Marine1981
Report this Post01-28-2019 09:30 PM Click Here to See the Profile for Marine1981Click Here to visit Marine1981's HomePageSend a Private Message to Marine1981Edit/Delete MessageReply w/QuoteDirect Link to This Post
Great thread. I'll probably have to do this in my chop top.
jscott1
Total ratings: 415
Report this Post01-30-2019 08:07 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes that is exactly how Archie did it. He also scooped out about an inch of foam from the seats. My seats were too low for me. I added an inch of foam back to the seats else I couldn't see over the dash.
Spadesluck
Report this Post01-31-2019 05:15 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jscott1, how tall are you?
FierociousGT
Total ratings: 131
Report this Post04-24-2021 10:03 PM Click Here to See the Profile for FierociousGTSend a Private Message to FierociousGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, needed this and was wondering how it should have been done. 👍🤠
Australian
Report this Post04-24-2021 10:31 PM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is done with custom rails.
Report this Post04-26-2021 10:33 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you try this....
Use Fender Washers or other ways under the car to spreed load for the bolts.
Coat the "fenders" and bolt heads w/ whatever anti-rust and/or sealer too.
Seats hardware put stress on the floor for point loads and can fail over time "ripping out" of the floor. Or if you wreck, the floor can be very weak and fail then.
Many seats w/ bolts or studs installed on or going thru the floor pan directly have this done by adding extra layer spot welded in these areas. (Seat Belt bolts often have same thing too.)
Lower OE seats and some aftermarket seats w/ same base height or less can mess up Seat belt angles.
Lower other seats from other cars may be needed to restore head room and seat belt angles.
OE seat belts have wider range of angles on them so may not matter so must depending on size of driver etc.
Be glad you have a Fiero in rear end crashes...
Many GM and others front seats are weak at point where upper and base meet and fold back in a rear ender when speeds from vehicle hitting you is above a few MPH. More so w/ many recliners seat designs.
Rear wall of Fiero prevents this.
