  Junkyard EGR valve? Need an expert opinion.
Junkyard EGR valve? Need an expert opinion. by RACE
Started on: 08-26-2003 11:34 AM
Last post by: RACE on 08-27-2003 12:17 AM
RACE
Total ratings: 157
Report this Post08-26-2003 11:34 AM Click Here to See the Profile for RACEClick Here to visit RACE's HomePageSend a Private Message to RACEDirect Link to This Post
I am faced with a decision. My wife's 3.1L Lumina needs an EGR valve. New, they are between $170-240. However, my local junkyard has quoted me a price between $10 and 15 for one.
Is there any reason that the junkyard valve would not be a good choice, or is new the only way to go?
Thanks,
Kenton
Owner since December 6, 2002, 1st Fiero, 1987 SE, 2.5, Auto.
Hank is Here
Total ratings: 103
Report this Post08-26-2003 11:36 AM Click Here to See the Profile for Hank is HereSend a Private Message to Hank is HereDirect Link to This Post
I'd go with the JY one. Even if the valve is bad you could buy a dozen of them and still be ahead of the game.
862M4inCA
Report this Post08-26-2003 05:35 PM Click Here to See the Profile for 862M4inCASend a Private Message to 862M4inCADirect Link to This Post
What I would suggest is picking up a vacuum pump to test the valve. Apply vacuum to the valve and see if it holds, if it does, the diaphragm should be good (the most common failure location). This will save you the trouble of removing a bad one. Most vacuum pumps have a dial to indicate how much vacuum you are applying as well as indicate if there is a leak by reflecting a drop in vacuum on the guage. A good EGR valve should not leak at all.
fierospeeder
Total ratings: 61
Report this Post08-26-2003 10:31 PM Click Here to See the Profile for fierospeederClick Here to visit fierospeeder's HomePageSend a Private Message to fierospeederDirect Link to This Post
like everyone said above
Plus, you want to stick your fingers underneath and push up on it. It should return back down.
Another problem, is when they stick and dont want to come down.
When your pulling them, look for a low mileage car, and one that doesn't have much carbon.
And just buy 3 or 4 and see which one works.
Steve Normington
Total ratings: 155
Report this Post08-26-2003 10:51 PM Click Here to See the Profile for Steve NormingtonSend a Private Message to Steve NormingtonDirect Link to This Post
Based on the price, I'd say he has one of the electronic EGR valves with the stepper motor to control the exhaust.
FYI, if this is the case (it has a connector with 5 small pins), I have one that was working when I pulled it off my donor engine (1997 3400 Silhoutte).
RACE
Total ratings: 157
Report this Post08-27-2003 12:17 AM Click Here to See the Profile for RACEClick Here to visit RACE's HomePageSend a Private Message to RACEDirect Link to This Post
Thanks for the info. I will have to see what sort fo luck that I have tomorrow.
