  Here's my 1st Tech Question....
Here's my 1st Tech Question.... by FieroGTGirl
Started on: 05-06-2000 04:30 PM
Last post by: GT-maniac on 05-08-2000 11:32 PM
FieroGTGirl
Report this Post05-06-2000 04:30 PM Click Here to See the Profile for FieroGTGirlSend a Private Message to FieroGTGirlDirect Link to This Post
What is the first thing to check when your windshield wiper fluid doesn't work(yes guys...I have checked if there was fluid in the reservoir)
DXR_DAD
Report this Post05-06-2000 04:36 PM Click Here to See the Profile for DXR_DADSend a Private Message to DXR_DADDirect Link to This Post
Check the little hoses, the do get pluged some times. Any gunk in the bottle?
phillip
No longer registered
Report this Post05-06-2000 04:43 PM   Send a Private Message to DXR_DADDirect Link to This Post
stuff to try. can you hear the washer pump working with some one holding the switch? no puddles from a broken hose? got a meter to see if you have voltage to pump when switched on? maybe switch feels different (broken)?
GT Bastard
Report this Post05-06-2000 04:44 PM Click Here to See the Profile for GT BastardClick Here to visit GT Bastard's HomePageSend a Private Message to GT BastardDirect Link to This Post
Is it completely dead, or does it just work very poorly? Do you have a shop manual yet?
FieroGTGirl
Report this Post05-06-2000 05:57 PM Click Here to See the Profile for FieroGTGirlSend a Private Message to FieroGTGirlDirect Link to This Post
Thanks for the advice I will check into it.
SCCA FIERO
Total ratings: 93
Report this Post05-06-2000 08:25 PM Click Here to See the Profile for SCCA FIEROSend a Private Message to SCCA FIERODirect Link to This Post
100 bucks says it's the pump. Look at the tank and you will see a black tubular thing sticking out of it with hoses attatched to it. This just twists out. If you don't have/can't find another one I have one I know works I will give you.
fierospeeder
Total ratings: 61
Report this Post05-06-2000 10:40 PM Click Here to See the Profile for fierospeederClick Here to visit fierospeeder's HomePageSend a Private Message to fierospeederDirect Link to This Post
Mine went dead on my 84 fiero, so i just guessed thats what was wrong with it. I went to the junkyard and pulled one from a fiero, there is no screws holding it. Payed a couple of bucks and mine is back to normal.
Linx
Report this Post05-07-2000 09:44 PM Click Here to See the Profile for LinxSend a Private Message to LinxDirect Link to This Post
Holy cow- you went to a junk yard for a washer motor? These are srandard GM issue...Autozone sells 'em for $8. And thyere held in by a grommet. 15 second repair...everything on this car should be that easy...like the dew wipes for instance.
sid1200
Report this Post05-08-2000 03:40 AM Click Here to See the Profile for sid1200Send a Private Message to sid1200Direct Link to This Post
have a similar problem to this, except one of my nozzles works but not the other, cleaned it out and it worked for a week or so then problem returned, any advice? did I not clean well enough,if not what is the best cleaning method
thanks
GT-maniac
Report this Post05-08-2000 11:32 PM Click Here to See the Profile for GT-maniacSend a Private Message to GT-maniacDirect Link to This Post
I have this problem too, my washer doesn't seem to work at all. When I press the switch I can't hear anything. I replaced the pump but I think the problem may be a lack of power. The under hood light doesn't work either, are they on the same circuit ? Is their something else on the same cicuit ?.
My car has lots of electrical problems. The power trunk release, oil pressure gauge, license plate lights and trunk lights all don't work either. A friend gave me a multimeter but how do I use it to test for power ? or if the wiring is broken ?
