Those of us thinking about this swap probably need more Q &A details.
You need the adapter brackets. OK this is a given.
If you use the Corvette C5 calipers that means that you must use the C5 rotors that have a different bolt pattern on the hubs.
What machining steps are necessary?
Assume that you need 17" rims, the Corvette Master cylinder, brake booster and most likely longer brake lines.
If there is a video on how this is done please point us to it. Thanks
