What I have is the T-Top Frame, both T-Top glass tops, front edge trim, rear trim, all the cap trim and interior "A" pillar trim.
Someone already got the roof weather seal (rubber gasket), I pulled the front trunk rubber seal and put it between the frame and glass to provide a soft cushion but you will need to source new window/top gasket. Here is a link to a thread where someone installed newer Camaro seals:
https://www.fiero.nl/forum/Forum2/HTML/104028.html Also already taken was the "A" and "B" front/rear brackets. These are the pieces that the tops "fit" into. (parts 11 and 14 on the exploded view below) Also missing is the windshield header reinforcement, it was pop-riveted into the front of the chassis with a bunch of rivets and I could not get it out (part 9). All that would be needed for this is a piece of 1"x1" square tube w/ a slight bend in it. "P" seals were shot so they are not included either.
more pics.
I didn't remove these parts. When I got to the yard on the last day, someone had ready tried to remove the top. They drilled out the rivets but they bent the edge of the rear corners. For whatever reason, the only parts they were after was the corner brackets. I've been able to reshape and flatten out the corners, but when it is installed, you will have to do some bending. The frame is not bent except for the rear corners. If your going to cut your roof off, and install this frame, fitting it should not be a problem for you.
The front and rear trim are included, the only issue is that one of the rear plastic parts has a crack. I plan to epoxy it so it does not get any worse. The cap trim are also brittle and need to be painted gray, brown or beechwood.
I'm asking $300. The way I see it, you're paying $100 for the frame, $100 for each T-Top glass and the rest is free. No way its getting shipped, unless you really want to pay for shipping.
PM me for any other information.
88 Coupe, CJB #95, LS376, F40 and a GT clip
88 GT "Daily Driver" w/ SIII 3800 NA
[This message has been edited by qwikgta (edited 11-03-2017).]
