Washer there needs a thicker hard one or make one out scrap steel.
Or if you spare OE bolts w/ captive washers... may find good replacement there... better if washer has "teeth" sim to HL Lift Nuts w/ captive washer to mount to the "Frunk" wall.
The small bolt works w/ long bolt to tension the pulley.
If long bolt & clamp ends are loose or lube wrong then small bolt often won't hold tension & belt have a very short life.
Carefully lube the long bolt &/or inside of alt where goes thru so can't "rust" but keep all lube off faces where bracket & alt hits.
Same if use anti-seize for short bolt threads... Keep lube off of head etc that clamps the work.
