Whattup, I have a 1984 fiero with the 2.5 out of an 1985 fiero
So I finally got my fiero running but it aint running right, and now it wont run at all. It just backfires out of the intake and wont start and I dont know why. Ive replaced the MAF sensor, ive set the ignition timing to 8 degrees (At least i thought i have), Ive preplaced the leaky injector and Ive replaced spark plugs. I checked all of the vacuum lines and they all seem to be fine.
It wants to run, you can feel it try to stay above 1k RPM but it just dies if you dont have your foot on the gas.
Issues that I am aware of right now is I do have really old gas and a bad fuel filter, but can bad gas really affect the preformance of an engine this bad? I think I set the ignition timing right, i heard its supposed to be 8 degrees advanced so I marked where I thought 8 degrees was on the degree thingy by the harmonic balancer. When I first started it initially it would run then die, so I got my brother to keep his foot on the gas to keep the engine as close to 1k rpm as possible so i could set the ignition timing, hoping it would help it run. It was a few degrees retarded so i advanced it to where I thought it should be at and it improved how it ran, but it still didnt idle properly.
I marked where I thought 8 degrees was on the degree thingy with silver sharpie so it would be easier to see when timing it.
but Ive tried to start it now it just backfires out of the intake which makes me think its either a gas or ignition issue
Help pls,
thanks much
James Bird
