| quote | Originally posted by rehoward:
What I am really looking for is an SC motor as they are reported to have all the goodies, steel crank, sintered steel rods, hypoeutectic pistons. Maybe other stuff I am not aware of. My plans are to drop an SC motor into the car and run the SC until I can get a turbocharger put together. Then replace the SC with the turbo.
Is there a particular year or model of a factory supercharged engine I should be looking for?
Thanks for the help.
Randy |
No 3800 SC engine ever came with a steel crank - they all received cast iron cranks.
3800 Series 1 and 2 Supercharged engines had cast connecting rods. 3800 Series 3 engines (I think) had powdered metal connecting rods.
3800 Series 1 engines have very little performance aftermarket support. Their design is based on the old 3.8L V6 which has a 1" taller deck height (making the engine taller and wider) than the Series 2 and 3 3800's.
3800 Series 2 and 3 engines are essentially the same concerning hard parts except for the aforementioned connecting rods. The only reason the 3800 Series 3 SC engine made 20 more HP than the Series 2 as due to the improved Gen5 blower.
If you are planning on doing a turbo build, you can use any Series 2 or 3 Supercharged engine. The stock internals will endure 7-13 psi of boost reliably, perhaps higher boost levels if you are running E85 or race gas. The biggest issue with these engines is the stock pistons; more precisely the placement of the top compression ring land (too close to the top of the piston - which exposes it to more heat) and a very tight factory ring gap (which was done for emissions). You need to be careful with stock pistons and ring gap specs if you plan on running a lot of boost with a turbo.
Check out my website for more info about my Turbo 3800 builds, and feel free to email or PM me if you have any questions (as I don't have time to visit this forum very often).
-Ryan
More is more. Less is not enough.
