I have been trying for months to start my 93 Cadillac swap to no avail. It once ran ok but will not start again. We have fuel pressure but no injector pulses and no spark. New distributor put in. After checking for battery power, ign+ and all grounds at the ECM they all check out. The scan tool says "neutral safety switch" but the starter engages and turns over. In doing further research I find that another lead from the neutral safety/trans selector switch goes to the ECM as "trans input P" I would like to test this input but unsure if it supposed to be a ground or a 12V input. I believe that without a ground or some signal to pin A2 the ECM won't turn on. Can anyone suggest a solution?
Thanks Joe. Will test first but if N/C I'll hook ECM pin A2 to ground and see if that does it. Come to think of it I did change the Neutral safety/ trans range switch before this problem surfaced. It is indexed properly but it could be a loose connection or a bad switch. Scan tool still says "neutral Safety switch" so that may be it.
What phonedawgz said ^^^ But it could be more along the lines that the ECM is not getting the distributor reference signals. Maybe a bad ECM? I assume you have power at the injectors?
But, as per your specific question: technically A2 is "not needed".
IIRC the transmission inputs are a binary code for what gear is selected. That being said, I think the symptom when C10 and F7 are not connected, the car would stall when coming to a stop (or something along that line). So in theory it should start with none of the connections made. This would be simple to check by disconnecting from the transmission and just grounding C10 and F7 and leaving the others disconnected.
Standard transaxle: You must connect ECM C10 & F7 to ground, the other transmission pins can be removed.
Highlighted areas are 'must use' connections (in most cases):
NOTE: it was pointed out by ImperfectTruth that A7 is not highlighted and YES this is needed
During cranking (under 400 rpm) the PCM/ECM does not control spark. The problem isn't going to be PCM based.
You have power going to the dist, I assume, why don't you have spark?
Yes power is going to the distributor but no spark. Still don't know why I get the neutral safety switch code. Will check all fuses this week. This no start problem has had me stumped for quite a while.
Is pin B-12 actually 2000ppm instead of 4000ppm for the odometer? I'm looking to convert it to analog so my speedo becomes usable after switching to the F40.
[This message has been edited by lou_dias (edited 10-12-2023).]
I seem to recall that it was - but that was a long time ago for me to be certain. But in the back of my mind I seem to think I did check that as I was going to use it for something.
I agree with Joe, sounds like a ground. Did you check the C10 and F7 pins to make sure they are grounded?
C7 is the bypass to distributor C pin F-10 is the Pass key input but that has been already been shut off in the program. Unused. Will get back on this tomorrow.
Here is how the ECM determines the gear that the car is in - so basically all you need to tell the ECM is that the car is not in park for it to operate correctly with a manual transmission (the car has to think that it is in drive according to an old Rockcrawl post). Park setting is not required to start the car as it is not used in the manual transmission install - in fact as far as the ECM knows, the car is in drive (OD or 3rd gear).
I know you say the security lock is removed in the software, but are you sure it was removed correctly? I used the electronic module (available on ebay). I had it running at the wrong frequency and until I fixed it, the car wouldn't start and exhibited the exact same symptoms. The module is really cheap.... maybe worth giving it a try
This could be the issue, but generally the engine would still fire but it would die shortly after a second or 2.
