Take a look at this thread, should help with most of your current/impending questions:
https://www.fiero.nl/forum/Forum2/HTML/139530.htmlWould recommend darth from
http://www.gmtuners.com to get a basic tune done on your PCM after completing the physical part of the swap, to get the car going, then you'll need to have it tuned properly at a dyno tuning shop.
Also for motor and trans mounts Fierorog makes some very nice options and you can contact him on Facebook, he has other swap parts as well:
https://www.facebook.com/Fi...rts-185617138853928/If you need to have your swap harness made for you I believe 'olejoedad' makes them. My apologies if this is incorrect, he should be here on the forums to message. Also 'Phonedawgz' here on the forum use to make them and I belive his website is:
https://reddevilriver.com/ - I'm uncertain if he still is active though.
Good luck with your swap~
[This message has been edited by Steel (edited 05-13-2022).]
