  NEW TACHOMETER ISSUES
NEW TACHOMETER ISSUES by eti engineer
Started on: 01-23-2022 09:26 AM
Replies: 4 (132 views)
Last post by: phonedawgz on 01-24-2022 09:53 PM
eti engineer
Report this Post01-23-2022 09:26 AM Click Here to See the Profile for eti engineerSend a Private Message to eti engineerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gents,
I had posted earlier about my tach reading around three times higher than what my actual rpms are. I have been busy with the exhaust issue, but now that that is done, I would like to get the tach working.
Someone had suggested that maybe it needed to be calibrated, but in the meantime a new problem has cropped up. It still reads about three times what it should but then it intermittently pegs out regardless of my engine rpms. It doesn't do it while the car is idling, but when I am moving down the road it does. What should my next step be to get this cured?
Thanks in advance...
J Gunsett
Total ratings: 50
Report this Post01-23-2022 10:44 AM Click Here to See the Profile for J GunsettClick Here to visit J Gunsett's HomePageSend a Private Message to J GunsettEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a PM.
Total ratings: 568
Report this Post01-23-2022 10:49 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pegging the tach is different then reading high...
reading high often means board has problems w/ bad caps and/or resistors.
peg temp etc gauges means sender section of circuit is open.
but tach and speedo "meter" is driven by a chip. The chip itself or "meter" have problems. Could be loose "meter" connection to anything.
fierosound
Total ratings: 286
Report this Post01-23-2022 11:54 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
New circuit boards
https://www.fiero.nl/forum/Forum2/HTML/143834.html
Total ratings: 290
Report this Post01-24-2022 09:53 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
My replacement adjustable tachometer board, with options to include a precision calibration circuit and a low fuel light.
https://reddevilriver.com/Tachometers.html
