  4.9 caddy engine distributor
4.9 caddy engine distributor by Collector
Started on: 09-13-2021 05:39 PM
Replies: 7 (436 views)
Last post by: Collector on 09-17-2021 01:02 PM
Collector
Report this Post09-13-2021 05:39 PM Click Here to See the Profile for CollectorSend a Private Message to CollectorEdit/Delete MessageReply w/QuoteDirect Link to This Post
when using a caddy 4.9, and using a CARB and a 1 wire Distributor with NO Computer Controls, what Distributor is needed ? was remembering maybe a OLDS ? Help. thanks
Report this Post09-13-2021 07:59 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am pretty sure there is no plug & play solution, you have the assemble a modified distributor, or pay someone to do it for you.
If my memory is correct, you gut the stock 4.9 caddy housing, then you buy a 307 olds vacuum advance distributor for all the guts (it needs to be a reverse rotation setup vs. the SBC). You install the olds guts into the caddy distributor and cut down the shaft to the proper length. Probably a few more finer details, but overall that is what it takes. I followed the instructions below and did this sometime in the 2002 or 2003.
https://web.archive.org/web.../bubbajoexx/id18.htm
Edit: along the lines of paying someone to build it for you:
http://johns49performance.com/products.html
[This message has been edited by fieroguru (edited 09-13-2021).]
Total ratings: 328
Report this Post09-15-2021 09:24 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Carburetors went obsolete on vehicles 40 years ago. What don't you like about efficient fuel injection; a constantly adjusting system that optimizes spark, fuel and engine performance?
[This message has been edited by Dennis LaGrua (edited 09-15-2021).]
Collector
Report this Post09-15-2021 11:21 PM Click Here to See the Profile for CollectorSend a Private Message to CollectorEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not MY CAR. owner wants it "simple". 1 wire dist, carb (no wires or computer). just because something is 40 years old does not make it "bad". if it was Holley and edelbrock would be out of business. all my cars (owned them for 50 years each ) have carbs and 1 wire HEI. no electrical problems. not looking for MPG or emissions. everyone has a preference.
MarkS
Report this Post09-16-2021 08:13 AM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is a link to a carb'd 4.9 by Arns85GT. Holley 2bbl then to 4bbl DP
https://www.fiero.nl/forum/Forum2/HTML/127788.html
BR's,
Mark
1965 Tempest 400 CID
2018 Chevy Colorado Z71 3.6
2017 BMW X3 3.0 T
2015 BMW 535iX M Sport
2008 G6 GT "Street" Coupe 200K miles
2005 Buick 3.6 Rendezvous 225K miles
[This message has been edited by MarkS (edited 09-16-2021).]
Spadesluck
Report this Post09-16-2021 11:15 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
To add to that, you can also run a bigger cam because of the ability to change the AFR with jets in the carb. The computer for this motor is very limited. Delta Cams makes grinds for this scenario.
Total ratings: 237
Report this Post09-17-2021 10:24 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Other computers are available... like MegaSquirt
Collector
Report this Post09-17-2021 01:02 PM Click Here to See the Profile for CollectorSend a Private Message to CollectorEdit/Delete MessageReply w/QuoteDirect Link to This Post
do not WANT a Computer, any computer. ******* a carburetor and a HEI 1 wire distributor*****
