  A/C conversion problems
A/C conversion problems by sledcaddie
Started on: 06-20-2021 01:21 PM
Replies: 11 (383 views)
Last post by: RWDPLZ on 08-10-2021 08:06 PM
sledcaddie
Report this Post06-20-2021 01:21 PM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
1988 GT, V6, 5 speed, 12K miles: during A/C conversion to newer freon, still having problems with the radiator fan running continuously. Fan runs continuously, even when A/C is not selected. I have my mechanic doing this because I don't have A/C gauges and/or evacuation station. He has worked on Fieros before. We have tried the 3 trouble-shooting measures in the GM Fiero service manual: unplug coolant temperature switch, unplug hi-pressure cutout switch, disconnect A/C control head connector. Fan still runs. He even tried a different manufacturer's hi-pressure switch, but fan still ran. To verify the hi-pressure switch, he evacuated the system, so there was no pressure. Fan did NOT run. As soon as he charges the system, and it is under pressure, the fan stays on again.
Could we have the wrong compressor? Maybe one that puts out pressure that is too high?
Like many Fiero owners, we have chronic migraines from banging our heads against the wall, trying to diagnose issues. Any help would be greatly appreciated!
Total ratings: 328
Report this Post06-20-2021 09:26 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The fan running continuously will not present any problems. As soon as you turn the AC on that fan will energize and run continuously. On my 3800SC swap that I did 10 years ago the fan goes on pretty quickly and stays on. No problems so far. Actually when the AC is off. The radiator fan on the FIero is controlled only by a sensor switch on the engine.
[This message has been edited by Dennis LaGrua (edited 06-20-2021).]
Total ratings: 154
Report this Post06-20-2021 09:32 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you installed the new style pressure switches, that could be the problem. A number of folks have had that issue. Don't know the cure other than to find the old style pressure switches.
Check the fan relay under the left headlight for a jumper wire.
[This message has been edited by fierofool (edited 06-20-2021).]
RWDPLZ
Total ratings: 306
Report this Post06-20-2021 11:37 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
You only mention 1 switch, but there should be 2 in the rear of the compressor. What part number switches did you use, and what color wires are hooked up to each?
sledcaddie
Report this Post06-21-2021 09:14 AM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I already checked for a jumper wire there, but no evidence of that.
sledcaddie
Report this Post06-21-2021 09:16 AM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
sledcaddie
Member since Aug 2011
[QUOTE]Originally posted by fierofool:
What are the old style switches? Are these the kind that the Fiero Store sells?
Should we replace the new switch with the one we removed?
sledcaddie
Report this Post06-21-2021 02:09 PM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
sledcaddie
The fan running continuously will not present any problems. [u][b]As soon as you turn the AC on that fan will energize and run continuously..
The problem is that the fan runs ALL THE TIME, even when the A/C is not selected. So, in cooler weather, the fan running constantly could prevent engine from reaching correct operating temp.
Ronbo4786
Report this Post06-29-2021 01:07 PM Click Here to See the Profile for Ronbo4786Send a Private Message to Ronbo4786Edit/Delete MessageReply w/QuoteDirect Link to This Post
Having recently converted my system and researching the forums I found a thread that discussed cutting the ground to one of the two pressure switches (high or low) from the back of the compressor. If you do a search for AC pressure switch you should be able to find the thread. When I cut the ground it stopped the fan from coming on at settings other than AC or defrost.
Hope this helps!
1986 Fiero GT
Muncie 4-speed
2.8L V6
sledcaddie
Report this Post06-29-2021 02:28 PM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Ronbo4786:
". When I cut the ground it stopped the fan from coming on at settings other than AC or defrost."
Hope this helps!
Thanks for your input on what topic to enter into "search". I found several links to this issue. Most of what I found said to NOT cut the ground. If not grounded, the compressor will not kick on.
sledcaddie
Report this Post06-29-2021 05:06 PM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
sledcaddie
What is the correct color wire for the A/C cutout switch? (dark green?)
What is the correct color wire for the A/C high pressure switch? (black?)
What happens if the wires are switched?
[This message has been edited by sledcaddie (edited 06-29-2021).]
RWDPLZ
Total ratings: 306
Report this Post06-29-2021 06:38 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure about the later years, but in the 84 manual, the high-pressure cut-out switch is black, and the fan switch is yellow.
RWDPLZ
Total ratings: 306
Report this Post08-10-2021 08:06 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
resolution: Install correct compressor-mounted fan switch
https://www.fiero.nl/forum/Forum2/HTML/145365.html
Originally posted by sledcaddie:
Finally! The shop that was doing my A/C conversion was able to diagnose the problem of the radiator fan staying on all the time.
The fan would not be running until the system was charged with freon. Then, it would run continuously, even with the A/C off. The issue was the compressor switch on the backside of the compressor. He had tried 3 other switches (different brands) with the same results of the fan continuing to run. Finally, he used the FourSeasons switch, and the fan only runs when the A/C is on Max, or the temperature sensor reaches a high enough temp to trigger the fan.
I hope this helps anyone else who has had troubles during A/C conversions. Thanks to all on Pennock's whose input helped us down the road to solving this issue. My Fiero is BACK!
Attached is a photo of the parts box for the compressor switch that worked properly.
