  No start
No start by AL
Started on: 04-01-2021 07:52 AM
Replies: 3 (87 views)
Last post by: phonedawgz on 04-01-2021 11:25 PM
AL
Report this Post04-01-2021 07:52 AM Click Here to See the Profile for ALSend a Private Message to ALEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is my problem, my Indy sometimes when I go to start it,it won’t crank when I turn the key, I changed the ignition switch the
Ignition lock key and the starter, also new battery, I’ve checked my wires and power seems to reach the starter but no crank, so if I want it to crank I apply a screw driver to the starter to activate it and then I turn the key and it starts up, any ideas?
Total ratings: 206
Report this Post04-01-2021 09:14 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Manual trans - check the clutch safety switch (purple and yellow wires on plug.
Automatic - check adjustment on neutral safety switch on transmission below the shift lever on transmission.
AL
Report this Post04-01-2021 01:24 PM Click Here to See the Profile for ALSend a Private Message to ALEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you I’ll check that.
Total ratings: 290
Report this Post04-01-2021 11:25 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
The nut on the battery cable of the starter has loosened a bit.
