  Isuzu 5 speed no reverse
Isuzu 5 speed no reverse by NuttyToe
Started on: 11-02-2020 06:55 PM
Replies: 14 (440 views)
Last post by: fieroguru on 03-13-2025 04:21 PM
NuttyToe
Report this Post11-02-2020 06:55 PM Click Here to See the Profile for NuttyToeSend a Private Message to NuttyToeEdit/Delete MessageReply w/QuoteDirect Link to This Post
New to Fiero's but have been working on cars for years. Looked through searches and couldn't find anything helpful. Just swapped in a junkyard 5-speed Isuzu in to replace a blown up 4-speed. Everything has been fixed and shifts great 1-5 WITH AND WITHOUT CABLES.
However, I cannot get the car to shift into reverse no matter what I do. Cables have been adjusted numerous times to try and help and tested with them disconnected. It just won't go into reverse. Ran 1-5 on jack stands and no weird noises or anything. I'm thinking the trans reverse gear is bad or something, any suggestions?
Total ratings: 463
Report this Post11-02-2020 11:28 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I assume you installed a 5-spd shifter?
If you disconnect the cables at the transmission, are you then able to move the levers on the tranny and put it into Reverse?
NuttyToe
Report this Post11-03-2020 12:32 AM Click Here to See the Profile for NuttyToeSend a Private Message to NuttyToeEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is a 4 speed shifter but modified it so it is the same as a 5 speed regardless.
With the cables completely disconnected I cannot get it into reverse. Goes into 5th fine but can't go into reverse.
skywurz
Report this Post11-03-2020 01:43 AM Click Here to See the Profile for skywurzClick Here to visit skywurz's HomePageSend a Private Message to skywurzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you flip the selector over if its not from a Fiero?
Probably dumb question but you are not going 5th to reverse are you? It will lock out.
Total ratings: 463
Report this Post11-03-2020 01:45 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, that does not sound good. I'm aware that Isuzu's 2nd gear can pack it in, but I'm not familiar with any Reverse issues. Perhaps a transmission expert can chime in here.
Report this Post11-03-2020 08:17 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since you're new to Fieros, I'll throw this out. The 4-speed has reverse located to the left and forward, up beside First Gear. The Isuzu has reverse located to the far right and back, down beside Fourth Gear.
NuttyToe
Report this Post11-03-2020 10:05 AM Click Here to See the Profile for NuttyToeSend a Private Message to NuttyToeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry not sure what you mean by selector, the trans is from a 2.5 fiero same year.
I am not specifically going reverse from 5th, just know they are on the same shift fork which is why I included that. I've heard some people have broken shift forks and then they can't get into 5th or reverse when that one is broken. But my 5th works fine.
NuttyToe
Report this Post11-03-2020 10:06 AM Click Here to See the Profile for NuttyToeSend a Private Message to NuttyToeEdit/Delete MessageReply w/QuoteDirect Link to This Post
NuttyToe
Member since Oct 2020
Yes, did know that. Same pattern as my Wrangler. Appreciate the help though.
NuttyToe
Report this Post11-03-2020 10:11 AM Click Here to See the Profile for NuttyToeSend a Private Message to NuttyToeEdit/Delete MessageReply w/QuoteDirect Link to This Post
NuttyToe
Sorry, what do you mean by packing it in? Never heard that phrasing before. But yes not sounding too good, I'm thinking it's reverse gear gone out but not 100% since I feel like it should at least grind or something. It's almost like I can't get past the reverse lockout.
Total ratings: 463
Report this Post11-03-2020 01:07 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Quitting, or perhaps moreso in this scenario... failing. I was originally going to say "goes away", as 2nd gear just isn't there anymore when it fails, but I thought maybe that phrase might've confused you!
NuttyToe
Report this Post11-03-2020 03:12 PM Click Here to See the Profile for NuttyToeSend a Private Message to NuttyToeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Haha gotcha, I figured that's what you meant but didn't want to assume. Thanks for the reply
NuttyToe
Report this Post11-20-2020 11:49 PM Click Here to See the Profile for NuttyToeSend a Private Message to NuttyToeEdit/Delete MessageReply w/QuoteDirect Link to This Post
If anyone cares, it ended up just being a really stuck reverse shift fork. Slammed super hard into reverse and it works just fine now.
Total ratings: 463
Report this Post11-21-2020 12:14 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
If anyone cares...
It's always appreciated when people make the effort to report back and bring some closure to a thread. It might help the next person who experiences the same problem. So thanks.
luso31893
Report this Post03-13-2025 04:07 PM Click Here to See the Profile for luso31893Send a Private Message to luso31893Edit/Delete MessageReply w/QuoteDirect Link to This Post
How exactly were you able to slam it in? At the trans or at the shifter itself? Mine just lost it in winter and then came back randomly but has once again gone away.
Report this Post03-13-2025 04:21 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might try removing the reverse light switch. It has a ball detent and if stuck will make shifting into reverse more difficult.
