  Relocated battery under headlight
Relocated battery under headlight by GTFiero1
Started on: 05-16-2020 03:28 PM
Replies: 15 (560 views)
Last post by: Dennis LaGrua on 05-30-2020 05:24 PM
GTFiero1
Total ratings: 109
Report this Post05-16-2020 03:28 PM Click Here to See the Profile for GTFiero1Send a Private Message to GTFiero1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Figured I share my battery relocation. Wanting preserve as much room in front compartment as I could, i wondered if anyone put their battery in the empty area under headlight/in bumper. Did a search here and low and behold, I found and old thread where FieroGuru had done just that. I based basic tray off his design and went from there.
Tray is 16ga steel, hold down 1/8 x 1.5 plate. Cut out sheet metal under headlight and fitted tray to be spot welded in the rear, and welded along edge up front as lip was thin. Hold down bolts to frame and J hook to tray itself. Small tab on bottom for nose support. Drilled out the old horn mount hole and welded an M10 nut that will serve as the grounding lug for the battery. Positive will have a 200a breaker right off the terminal
--Adam-- ASE Certified Technician
[This message has been edited by GTFiero1 (edited 05-16-2020).]
GTFiero1
Total ratings: 109
Report this Post05-16-2020 03:37 PM Click Here to See the Profile for GTFiero1Send a Private Message to GTFiero1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Couple pictures didnt upload right
Spoon
Total ratings: 61
Report this Post05-19-2020 08:46 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice job. I did mine about a year ago using aluminum plate. Took pics but don't recall posting anything.
Spoon
longjonsilver
Report this Post05-21-2020 11:02 AM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
i did mine under the headlight and i love how Freya handles then, and that is in comparison to the battery in the spare tire!
Here is my thread:
https://www.fiero.nl/forum/F...1/HTML/098244-2.html
i got the idea from Lunatic:
https://www.fiero.nl/forum/F...3/HTML/000148-3.html
jon
I'm the original owner of a white ' 84 2M4 purchased Dec 10, 1983 from Pontiac. Always garaged, no rust, 4-wheel drifts are fun!
Report this Post05-21-2020 07:39 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the shoutout! I was going to say that looked awful familiar! From back in 2008:
https://www.fiero.nl/forum/A...090907-2-093154.html
In 2012 When I built my LS4/F40 car I went a different path. I switched to a small dyna-batt battery and made a try that fit under the sheet metal. Less weight, no trimming of chassis sheet metal required.
Then I worked on the battery mount. I fabbed up these brackets to hold the battery, but ended up unbending one of the bolted flanges.
The battery is now mounted under the passenger head light, but the only modification to the sheet metal in that area was to drill seven 1/4" holes and remove the protruding flange from the 1" diameter drain hole on the bottom side. In the first picture you can see that the battery easily clears the bottom of the 88 coupe fascia (notice the 2 bolt air ducting bracket on the other side of the battery).
The mounting bracket holds the battery firm in 3 directions and the batter hold down tab secures it in the 4th direction.
Mike in Sydney
Report this Post05-21-2020 08:19 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting project. I've seen battery relocation into the front compartment under the spare but this is the first I've seen off center. A couple of questions for you: 1) What's the advantage in relocating the battery to the front of the car? Do you notice any handling or ride issues with the additional weight of the battery so close to the front wheel? 2) What gauge wire do you use for the increased length of the battery leads?
Mike in Sydney
CDM
Report this Post05-26-2020 04:30 PM Click Here to See the Profile for CDMSend a Private Message to CDMEdit/Delete MessageReply w/QuoteDirect Link to This Post
@Fiero Guru
Can you give a little info on the BAT (battery) you have.
Positives an Negatives,
I read on the site it has 15hrs of energy, what does this mean.
Do I have to disconnect it when not in use, my fiero is rarely use, but if i fo out for a a weekend.
Should I have it on a constant trickler when in the garage?
Thank you in advance : )
Report this Post05-26-2020 04:59 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is absolutely no way that installing a regular sized battery at the corner of a car is going to improve handling compared to having it mounted low and centrally.
Report this Post05-26-2020 08:02 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by CDM:
@Fiero Guru
Dyna-batt is a relabeled/re-badged Motorcycle battery w/ high price really made by www.odysseybattery.com and Not made to start or run a car.
While fieroguru and few others likes/loves them, many have problems for many reasons.
Search archives here and internet.
CDM
Report this Post05-26-2020 11:07 PM Click Here to See the Profile for CDMSend a Private Message to CDMEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Ogre
Originally posted by theogre:
[QUOTE]Originally posted by CDM:
@Fiero Guru
[/QUOTE]
Report this Post05-27-2020 08:48 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
@Fiero Guru
I have ran the Dyna-Batt for 6+ years. It easily cranked over by LS4/F40 swap even when I left the car parked outside over winter for a month or two between starts. My car is a 3 season driver so while it would sit for a month or two in the winter, I never put it on a trickle charger, nor was there ever a need to.
These smaller batteries do not have the reserve capacity of a larger one, but as long as the car starts with the first 5 tries (if it doesn't, fix those issues) and your car doesn't have an electrical drain (like from a security system), it will start your car when needed. What it won't do is allow you to run accessories with the engine off as long as a full-size battery. So if you make it a habit of leaving your lights on when you park your car, or listening to the radio while the car is parked, that will result in a dead battery sooner.
If you store your car for months, or you have to run a trickle charger to keep a full-size battery charged between starts, you will likely have more issues with Dyna-Batt than I have.
As with any modification, go into it eyes wide open. Understand the benefits and compromises and pick your path. I am going to stick with the Dyna-Batt.
Total ratings: 236
Report this Post05-27-2020 09:31 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Right. The entire point of putting the engine in the middle is to collect the car's major masses into as small a footprint as possible. Moving the battery forward works against the reason the car is mid engine in the first place. Moving the battery also adds a bunch of copper to the car, and copper is heavy.
I think straight down from the stock location is about the best place in a Fiero to mount the battery... That keeps it as close as feasible to the engine for short cable runs, as close as practical to the car's CG without mounting it in the passenger compartment and puts it as low as possible in the car. I haven't done one like this, but the mini-battery shown above is especially well suited for that.
[This message has been edited by Will (edited 05-27-2020).]
GTFiero1
Total ratings: 109
Report this Post05-28-2020 11:38 AM Click Here to See the Profile for GTFiero1Send a Private Message to GTFiero1Edit/Delete MessageReply w/QuoteDirect Link to This Post
If I was actively autocrossing maybe I would keep it in spare tire compartment more centrally located. When this car is done it will see probably 90%+ normal/leisure driving (which is probably most fieros) to which the weight location will make no real difference.
I'll use 0 gauge cable (welding cable) to run to the back. Power only, as ground will be short right to that lug I welded to chassis. Using 200a breaker right off terminal for safety. Engine will have multiple ground straps to chassis.
Report this Post05-28-2020 12:10 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Using Car's frame as return ground from engine causes many problems. Far easier and worse if just 1 joint is dirty or loose.
Every joint adds resistance even when good sucking power creating lower volts to everything is bad.
Example: See my Cave, Electric Motors
But can be far worse...
Worse? How?
Like Iffy ground(s) can try to make coolant system to be a ground wrecking everything. Even rubber hoses. Coolant is good at conducting electric but will eat anything doing so. Even anti-rust chems in coolant wears out very fast when you have ground problems.
More so every time you start the engine as 1.5kw starter pulls ~ 120 amps just to run, inrush can be 200 to 300+ amps when first turn the key. Many have "upgraded" to 1.7kw starter that uses ~ 135 amps to run and higher inrush.
Total ratings: 236
Report this Post05-29-2020 10:37 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Worse? How?
BMW ran the return current through the chassis on the E30's they built with the battery in the trunk. I need to check my E34 and W211 to see if they're done the same way.
[This message has been edited by Will (edited 05-29-2020).]
Report this Post05-30-2020 05:24 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The small battery mentioned in this thread is probably 270 CCH capacity. That's less that 1/2 of the battery capacity that came with the car. You can probably get by starting an engine that turns over on the first try, but leaving the headlights on for a few minutes may be a different story. I guess that it works for some so more power to you!
