  Seville caliper questions
Seville caliper questions by coltabsh
Started on: 02-08-2020 09:50 PM
Replies: 4 (225 views)
Last post by: darbysan on 02-09-2020 10:56 AM
coltabsh
Report this Post02-08-2020 09:50 PM Click Here to See the Profile for coltabshSend a Private Message to coltabshEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have tried to search for more info on the Seville calipers upgrade but come up empty handed.
most of the info is missing the photos and the description are not clear with out the pictures .
I have ordered my brackets from dpwood.
1.What year Seville for the calipers.
2. Do I need rotors? what make and year?
3. I there a way to make the existing park brake cables work?
4. Does the bleeders point down and how do you bleed air out?
Thanks for any help
jjd2296
Report this Post02-08-2020 09:55 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
You talking about the zettner brake upgrade using 1985 Seville calipers? And 1990 Chrysler Lebanon rear rotors all around? If so message me your email I have the build list
fierosound
Total ratings: 286
Report this Post02-08-2020 10:54 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some info here:
https://www.fiero.nl/forum/A...120111-2-109042.html
coltabsh
Report this Post02-09-2020 10:54 AM Click Here to See the Profile for coltabshSend a Private Message to coltabshEdit/Delete MessageReply w/QuoteDirect Link to This Post
That would be it. I was looking under Seville, Seville upgrade, Seville rear calipers and only getting a few topics with no info
thanks so much
darbysan
Report this Post02-09-2020 10:56 AM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did this upgrade on my '87. Used Seville Calipers, bleed valve mounted up. Grand Am Rotors, Seville pads ( slightly modified), Stock parking brake cables work, but using Pontiac 6000 cable on one side makes the fit easier. Combined with Grand AM front upgrade, no proportioning valve needed. I did upgrade the Master Cylinder and the RD bigger brake booster.
Here's a thread that may help https://www.fiero.nl/forum/A...130314-2-083566.html
'87 GT , '00 3800 Series II SC, 4t65e, Vue Power Steering. (SOLD)
