Hi there, First day digging into the Fiero..... It has been standing in a barn for a good few years. Found this loom missing probably a connector. Unfortunately I can't appear to post a picture off my phone, and having read the bewildering PIP thing I can't use that either as I don't use a computer at home. ...
Is 2 pink and 2 white wires cut? missing the coil connector. anything will have HEI wiring as it does matter which color goes to A & B plugs on coil.
Rest of problem try to see my cave before posting as many are covered there.
Warning: very likely need to check all fluids and brakes before you try to start or worse try to put it in gear after starting.
Yep, the black connector is missing. There are two other wires in that cluster of wires one which is brown and black and the other red and black. What are they supposed to be connected to?
Yeah, the whole car will gone through before i even get to the turn over stage.
