| quote | Originally posted by edfiero:
About the only thing I've seen that is low cost and gives the Duke any more pep is to block off the EGR and to advance the timing 2 or 3 degrees. |
AFAIK, EGR function allows leaner mixtures to be run, with more timing and no detonation. If you eliminate EGR, its wise to increase fueling to compensate, then safe adjustments to timing can be tried. I would be inclined to not eliminate EGR and increase timing without fueling adjustments.
