  1984 Fiero Fuel Vapor Canister - Need Help Locating One
1984 Fiero Fuel Vapor Canister - Need Help Locating One by BillTrinaD
Started on: 07-27-2017 11:02 AM
Replies: 25 (1362 views)
Last post by: theogre on 04-28-2019 11:14 AM
BillTrinaD
Report this Post07-27-2017 11:02 AM Click Here to See the Profile for BillTrinaDSend a Private Message to BillTrinaDEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi everyone,
We've got this 1984 Fiero and absolutely love it. We need to purchase a replacement fuel vapor canister for the car, though (not the filter). We were told that a Borg Warner CP1038 is a replacement for the original Pontiac part #17075840. The problem is that we can't find any supplier of the Borg Warner canister.
We're hoping someone else here has some suggestions. The best we've located is one used one in Alabama. We live in CA with really strict emissions controls. Thanks for any assistance.
Best,
BillTrina
Report this Post07-27-2017 11:09 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
You don't need it. Just excess equipment that does nothing. I don't use them and no I'll effects.
ltlfrari
Total ratings: 127
Report this Post07-27-2017 11:15 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you really try looking, 2 seconds on Google....
https://www.summitracing.com/parts/smp-cp1038
Dave
www.ltlfrari.com
[This message has been edited by ltlfrari (edited 07-27-2017).]
BillTrinaD
Report this Post07-27-2017 11:24 AM Click Here to See the Profile for BillTrinaDSend a Private Message to BillTrinaDEdit/Delete MessageReply w/QuoteDirect Link to This Post
The part mentioned at the racing location is actually a SMP (Standard Motor Parts, also available at Rock Auto) CP1038 and that part does not fit the 1984 Pontiac Fiero (or any other Fiero actually). Yes, we did search. We need a Borg Warner CP1038, which is a completely different company and different part. There's one that pops up at Amazon, but it looks like the part might be discontinued.
And yes, we do need this part for the strict emissions controls out here in California or the vehicle will not pass the smog test at its next registration.
I've contacted several parts companies and the Borg Warner company directly to see if there is a supplier for this part.
Thank you for the replies.
Report this Post07-27-2017 12:29 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the other brands have the same ports, couldn't it be used by fabricating a different mount or modifying the present mount? They all should function the same.
Report this Post07-27-2017 12:41 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Go to any junk yard and look in any old GM car.
Part was used for many GM cars in the 80's.
Some have this hidden in a "case" to protect it. Follow 2 vac lines and 1 fuel vent line going into a bigger can/case on the frame, inner fender, etc.
If bottom filter is bad is a Frame "filter" # BA3865 to replace the floss. Can get them RA and many others. can likely find floss to make one at fabric, fish, or hobby stores.
Filter is there just to keep big crap plugging the bottom.
Note that GM Part Numbers can and does change... 22P list that as 17075840 but GM long since charge the PN.
I found this...
048 FILTER. Early Fuel Evaporation Control. Fuel Tank Evaporator/Purge Control. GM P# 07021743 $24.27
Other numbers 7021743
at http://www.wholesalegmparts...&ukey_category=19400
Short List this is used in:
This product fits 175 vehicle variants.
Buick: 4 models, 32 variants between 1984 and 1988.
Chevrolet: 3 models, 19 variants between 1984 and 1988.
Oldsmobile: 6 models, 59 variants between 1984 and 1988.
Pontiac: 6 models, 65 variants between 1984 and 1988.
[This message has been edited by theogre (edited 07-27-2017).]
BillTrinaD
Report this Post07-27-2017 12:55 PM Click Here to See the Profile for BillTrinaDSend a Private Message to BillTrinaDEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the additional suggestions. It is not the filter that is bad. The seal on the canister has broken. The entire canister needs to be replaced.
We are definitely looking to see if this part can be taken from a different model. There are some 1986 Fieros in the Pick and Pull lots about 2 hours out. That's our next call - to check with them to see if there's an interchangeable part.
I appreciate the assists!
Report this Post07-27-2017 01:02 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Go to link above and look at long list there shows every car used.
Many old Fiero EVAP can's are faded but should still works.
FWD car's EVAP can's are hidden from the sun and look new.
Report this Post07-27-2017 01:33 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Mar 99
All basically work the same but Making one to fit likely won't pass in CA and some other states.
Some states still forces to pass EVAP test for old cars. This includes pinching off Fuel Vent tube at the EVAP can. If can doesn't look OEM then except to fail.
EVAP test is testing 2 parts.
Gas Cap test to see if it's good.
Tank test to see tank and fill/vent lines do not leak pressure. This is why the pinch the vent line to EVAP can. Problem is have to make sure the line is closed or you fail. Is why you go to inspection on slow days. Guys then have time to check the clamp tool is tight and test again before they fail you.
Many New cars can tell you if cap is loose because EVAP test is built into the car and set MIL light on when cap is loose/bad etc. (Is why new car w/ MIL on = checking the cap as first step. Is light goes off then likely just the cap. Go to AZ etc for free scanning later just to be sure.)
cvxjet
Report this Post07-27-2017 05:36 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I live in the east SF bay area...First, can someone post up pics of the 84 so we know what it's supposed to look like...Is it the same as my 85 V6? Basically, were there any differences, year-to-year?
Second, if they are the same, and you can't find one locally, I can go to a local JY and pick one up for you.....When there is one to go to....(At the moment there are not any closer than south San Jose...)
Report this Post07-27-2017 11:10 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
All Fiero are same and in same location for 85-88. Same part for 84 but mounting might be a bit different.
1 bolt to release the can, 2 I think to remove the bracket.
FWD cars listed have same part but often mounted "hidden" in/on car's engine bay sheet metal.
If stuck, Don't pull the lines off the plastic. If you can't pull rubber off metal lines then cut the rubber so you don't break the can.
Heat and UV in a Fiero can make the plastic brittle and easy to break.
In FWD, Heat could still get to the plastic but FWD hood protect for UV.
BillTrinaD
Report this Post07-28-2017 09:22 AM Click Here to See the Profile for BillTrinaDSend a Private Message to BillTrinaDEdit/Delete MessageReply w/QuoteDirect Link to This Post
cvxjet, thank you for the offer. Actually, we're in the Central Valley and can make the trip. Looks like there are some Fieros (not 1984 models) in some of the pull it yourself yards.
theogre, Thank you so much for all of the information. This has been a huge help. I think we'll have to venture down to one of the pull it yourself yards (about a 3 hour drive or so - maybe make a day of it) and check out the cars there. You've been really helpful and I really appreciate it.
sardonyx247
Total ratings: 219
Report this Post07-28-2017 09:56 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
For any parts compatibility, go to Autozone.com find the part and click on "Vehicle Fitment" it will tell you all(most) of the cars it fits.
BillTrinaD
Report this Post07-28-2017 10:04 AM Click Here to See the Profile for BillTrinaDSend a Private Message to BillTrinaDEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Sardonyx, we've been to several auto stores and are still checking. They aren't even sure. Part of the problem is that the part has been discontinued (original part and it looks like the Borg Warner might also have been discontinued). I've got a call pending to the Borg Warner headquarters and the guy at the local AutoZone and at the local O-Reillys have calls in to their parts gurus for us.
sardonyx247
Total ratings: 219
Report this Post07-28-2017 10:42 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
If it helps the 84's are the same as the V6s etc
Edit to add: If you can't find one I have used ones.
[This message has been edited by sardonyx247 (edited 07-28-2017).]
Report this Post08-07-2017 05:00 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry people,
To horror I find out that 07021743 (7021743 in some books) is ONLY the filter on the bottom of the EVAP can. Not the whole unit.
GM parts web sites and Ebay only list this part and pointed to the can in whatever diagram and list diagram number match the can too...
So can in diagram (87 4cyl) is 48... the filter shows as 48 and can isn't listed at all. (87 V6 is 72) Can is Not even shown as discontinued farther down on some site. Make it very hard to figure out.
Worse many parts don't have picture so no help that way.
Frame made the filters and sold for < $5
If you need a can then look for old 22p # for the can.
You can use same list for the filter to looking for other cars in junk yards.
GM often charge # so many times and 22P never listed the filter only. so I thought did same this time but no.
Sorry again.
[This message has been edited by theogre (edited 08-07-2017).]
Report this Post08-07-2017 05:10 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Mar 99
Full list... If have same filter then hopefully uses same can...
Buick Century 2DR Custom 1984, 1985, 1986, 1988
Buick Century 2DR LIMITED 1988
Buick Century 4DR Custom 1984, 1985, 1986, 1987, 1988
Buick Century Wagon Custom 1984, 1985, 1986, 1987, 1988
Buick Skyhawk 2DR CUSTOM 1986, 1987
Buick Skyhawk 2DR LIMITED 1987
Buick Skyhawk 4DR CUSTOM 1986, 1987
Buick Skyhawk 4DR LIMITED 1987
Buick Skyhawk Hatchback SPORT 1986, 1987
Buick Skyhawk Wagon CUSTOM 1986, 1987
Buick Skyhawk Wagon LIMITED 1987
Buick Skylark 2DR CUSTOM 1984
Buick Skylark 2DR LIMITED 1984
Buick Skylark 4DR CUSTOM 1984
Buick Skylark 4DR LIMITED 1984, 1987
Buick Somerset Base 1986
Chevrolet ASTRO 1985
Chevrolet Celebrity 2DR 1984, 1985, 1986, 1987, 1988
Chevrolet Celebrity 4DR 1984, 1985, 1986, 1987, 1988
Chevrolet Celebrity Wagon 1984, 1985, 1986, 1987, 1988
Chevrolet Citation 2DR Base 1984
Chevrolet Citation 2DR II 1984
Chevrolet Citation Hatchback II 1984
Oldsmobile Calais 2DR Base 1985, 1986, 1987
Oldsmobile Calais 2DR SUPREME 1985, 1986, 1987
Oldsmobile Calais 4DR Base 1986, 1987
Oldsmobile Calais 4DR SUPREME 1986, 1987
Oldsmobile Cutlass 2DR Ciera 1986
Oldsmobile Cutlass 4DR Ciera 1986
Oldsmobile Cutlass Ciera 2DR Base 1988
Oldsmobile Cutlass Ciera 2DR BROUGHAM 1984, 1985, 1986
Oldsmobile Cutlass Ciera 2DR BROUGHAM SL 1986
Oldsmobile Cutlass Ciera 2DR LS 1984, 1985, 1986
Oldsmobile Cutlass Ciera 2DR S 1987
Oldsmobile Cutlass Ciera 2DR SL BROUGHAM 1987, 1988
Oldsmobile Cutlass Ciera 4DR BROUGHAM 1984, 1985, 1986, 1987, 1988
Oldsmobile Cutlass Ciera 4DR LS 1984, 1985, 1986, 1987, 1988
Oldsmobile Cutlass Ciera Wagon LS 1984, 1985, 1986
Oldsmobile Cutlass Cruiser Wagon Base 1987
Oldsmobile Firenza 2DR Base 1986, 1987
Oldsmobile Firenza 2DR BROUGHAM 1987
Oldsmobile Firenza 2DR SX & LX BROUGHAM 1986, 1987
Oldsmobile Firenza 4DR Base 1986, 1987
Oldsmobile Firenza 4DR BROUGHAM 1987
Oldsmobile Firenza 4DR SX & LX BROUGHAM 1986, 1987
Oldsmobile Firenza Hatchback ACK 1987
Oldsmobile Firenza Hatchback Base 1986, 1987
Oldsmobile Firenza Hatchback BROUGHAM 1987
Oldsmobile Firenza Hatchback SX & LX BROUGHAM 1986, 1987
Oldsmobile Firenza Wagon Base 1986, 1987
Oldsmobile Omega 2DR Base 1984
Oldsmobile Omega 2DR BROUGHAM 1984
Oldsmobile Omega 4DR Base 1984
Oldsmobile Omega 4DR BROUGHAM 1984
Pontiac 6000 2DR Base 1987
Pontiac 6000 2DR STE 1984
Pontiac 6000 4DR Base 1987
Pontiac 6000 4DR LE 1987
Pontiac 6000 4DR SE 1986, 1987
Pontiac 6000 4DR STE 1984, 1985, 1986
Pontiac 6000 Wagon Base 1987
Pontiac 6000 Wagon LE 1987
Pontiac 6000 Wagon SE 1986, 1987, 1988
Pontiac Fiero 2DR Base 1984, 1985, 1986, 1987, 1988
Pontiac Fiero 2DR GT 1985, 1986, 1987, 1988
Pontiac Fiero 2DR SE 1984, 1985, 1986, 1987
Pontiac Fiero 2DR SPORT 1984, 1985, 1986, 1987
Pontiac Grand Am 2DR Base 1985
Pontiac Grand Am 2DR LE 1985, 1986, 1987, 1988
Pontiac Grand Am 4DR LE 1986, 1987, 1988
Pontiac J2000 4DR Base 1986
Pontiac J2000 4DR LE 1986
Pontiac J2000 4DR SE 1986
Pontiac J2000 Wagon Base 1986
Pontiac Phoenix 2DR Base 1984
Pontiac Phoenix 2DR LE 1984
Pontiac Phoenix 2DR SE 1984
Pontiac Phoenix Hatchback Base 1984
Pontiac Phoenix Hatchback LE 1984
Pontiac Sunbird 2DR GT 1987
Pontiac Sunbird 2DR HATCHBACK GT 1986
Pontiac Sunbird 2DR SE 1986, 1987
Pontiac Sunbird 4DR Base 1987
Pontiac Sunbird 4DR GT 1986, 1987
Pontiac Sunbird 4DR SE 1986
Pontiac Sunbird Convertible GT 1986, 1987
Pontiac Sunbird Convertible SE 1986, 1987
Pontiac Sunbird Hatchback Base 1986
Pontiac Sunbird Hatchback GT 1987
Pontiac Sunbird Hatchback SE 1987
Pontiac Sunbird Hatchback SE ACK 1987
Pontiac Sunbird Wagon Base 1987
Report this Post08-07-2017 05:32 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking in my copy of the P22 and comparing with a recent download from Nemiga.com shows all years have the same canister. Part # 17075840, described as Fuel Vapor Canister.
84 Emissions system. Item number 48
https://nemiga.com/cat_spar...c/22p-p/03/2p03-004/
85 and up Emission system, Item number 52
https://nemiga.com/cat_spar...c/22p-p/03/2p03-008/
BillTrinaD
Report this Post08-07-2017 05:56 PM Click Here to See the Profile for BillTrinaDSend a Private Message to BillTrinaDEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi everyone,
Thank you all so much for the responses and the assistance. The Pick N Pull place here, along with the help of Amazon.com (if you can believe that) led us to the correct part on a Buick. Yep, a Buick. The canister was in excellent shape and has been installed on the Fiero and now the car runs like a charm and should pass smog.
I appreciate everyone's input. Thanks especially to TheOgre. I haven't been here long enough to leave feedback for you all, but when I have, I will.
Report this Post08-07-2017 07:51 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes Nemiga echos 22P but look at most GM parts sites and only list a filter for the can, that's if they list anything at all.
You get Zero results search 17075840 too.
CLICK FOR FULL SIZE
wholesalegmpartsonline.com is/was/spinoff of Nalley GM Pontiac Fiero auto parts @ parts.nalleygmc.com if you try going to old addy get redirected to wholesale
I looked at other dealer sites and got same results. Price for filter should have been a sign but didn't register at the time.
Report this Post08-07-2017 08:26 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Mar 99
Originally posted by BillTrinaD:
Hi everyone,
Good it's fixed but Just How did Amazon help?
I order parts w/ them but had PN to find them.
Even ACdelco Dorman and Standard "books" don't vapor cans for Fiero
Never mind found BW part wlth list uses it. looks close to list above.
https://www.amazon.com/Borg...ity-chart/B000BZCSPO
Report this Post08-07-2017 08:44 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
While don't have, parts.sellersgm.com list 17075840 in:
Buick Century 1985, 1986, 1987, 1988
Buick Skyhawk 1985, 1987
Buick Skylark 1985, 1986, 1987, 1988
Buick Somerset 1986, 1987
Buick Somerset Regal 1985
Chevrolet Astro 1985, 1986
Chevrolet Celebrity 1985, 1986, 1987, 1988
Chevrolet Citation II 1985
Chevrolet S10 1985
Chevrolet S10 Blazer 1985
GMC S15 1985
GMC S15 Jimmy 1985
GMC SAFARI 1985, 1986
Oldsmobile Calais 1985, 1986, 1987
Oldsmobile Cutlass Calais 1988
Oldsmobile Cutlass Ciera 1985, 1986, 1987, 1988
Oldsmobile Cutlass Cruiser 1987, 1988
Oldsmobile Firenza 1985, 1986, 1987
Pontiac 6000 1985, 1986, 1987, 1988
Pontiac Fiero 1985, 1986, 1987, 1988
Pontiac Grand Am 1985, 1986, 1987, 1988
Pontiac J2000 Sunbird 1985
Pontiac Sunbird 1986, 1987
It looks like many dealers just slap a name on a site but all run the same backend service by 1 or 2 companies or even GM contact company.
I've seen this selling other things. Barcode readers sites are cookie cutter sites too.
Some X-refs are:
Factory Number
AIRTEX 4B1000
CARQUEST 73-10004
STANDARD MOTOR CP1021
WELLS VC118
WELLS 7310004
KEMPARTS 154108
BWD CP1038
ACDelco 215-35
ECHLIN 2-20028
But Found no live part available using them. Not sure trust them because yoyo and other parts searches.
BillTrinaD
Report this Post08-07-2017 09:46 PM Click Here to See the Profile for BillTrinaDSend a Private Message to BillTrinaDEdit/Delete MessageReply w/QuoteDirect Link to This Post
TheOgre,
Amazon helped because when I Google searched the exact part, it was actually listed there (although not available) and provided a huge list of compatible models. Some of those models matched what Pick and Pull had in the junkyard. I was quite surprised. It was, as Amazon so often is, the first option. I didn't pay much attention at first, but it was the only option that matched Borg Warner CP1038 exactly. And it had a picture. The picture looked like the part in the car. And it shows an extensive list of compatible models. I've pasted the link below. Several models would not have been matches as they aren't 2.5L and 4 cylinder, etc. But the list certainly helped. Thank you again.
Report this Post08-07-2017 09:58 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
An alternate that might work.
Standard CP1028. Is for GM 88-96 trucks.
http://ecatalog.smpcorp.com...ts/num/CP1028?type=s
https://www.summitracing.com/parts/smp-cp1028
4th port is air in. Doesn't vent air in from bottom.
You leave the "splash cap" on when car only uses 3 lines.
Not sure fits Fiero bracket. Neither have dimensions.
Might not pass in CA if they really look hard but should work.
I wanted a "backup" even tho currently fix right now.
Report this Post08-07-2017 10:01 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Mar 99
TheOgre,
Fiero and others w/ 4 cyl and 6 cyl all have same one.
Report this Post04-28-2019 11:14 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amazon Borg list as CSV... So you can try to find used parts in other GM cars. Many have this part hidden for crash safety etc. Follow 2 vac lines to frame or body.
Copy/past this quote section into notepad etc the save file as EvapCanList.csv
You can then double click to open in excel etc
Make ,Model ,Year ,Trim ,Engine ,Notes
Buick,Century,1988,Limited,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1988,Estate Wagon,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1988,Custom,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1987,Custom,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1987,Limited,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1987,Estate Wagon,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1986,Custom,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1986,Limited,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1986,Estate Wagon,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1985,Custom,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1985,Limited,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1985,Estate Wagon,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1984,Custom,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1984,Limited,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1984,Estate,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Century,1984,Olympia Limited,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Buick,Skyhawk,1987,Custom,Turbocharged SOHC 2.0L L4 Opel M GAS Distributor-Breakerless FI MFI Electronic MPI,FUEL VAPOR CANISTER
Buick,Skyhawk,1987,Limited,Naturally Aspirated OHV 2.0L L4 General Motors 1 Chevrolet GAS Distributorless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skyhawk,1987,T-Type,Turbocharged SOHC 2.0L L4 Opel M GAS Distributor-Breakerless FI MFI Electronic MPI,FUEL VAPOR CANISTER
Buick,Skyhawk,1987,Sport,Naturally Aspirated OHV 2.0L L4 General Motors 1 Chevrolet GAS Distributorless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skyhawk,1987,Sport,Naturally Aspirated SOHC 2.0L L4 Opel K GAS Distributor-Breakerless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skyhawk,1987,Custom,Naturally Aspirated SOHC 2.0L L4 Opel K GAS Distributor-Breakerless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skyhawk,1987,Custom,Naturally Aspirated OHV 2.0L L4 General Motors 1 Chevrolet GAS Distributorless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skyhawk,1987,T-Type,Naturally Aspirated OHV 2.0L L4 General Motors 1 Chevrolet GAS Distributorless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skyhawk,1987,T-Type,Naturally Aspirated SOHC 2.0L L4 Opel K GAS Distributor-Breakerless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skyhawk,1987,Limited,Naturally Aspirated SOHC 2.0L L4 Opel K GAS Distributor-Breakerless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skyhawk,1987,Sport,Turbocharged SOHC 2.0L L4 Opel M GAS Distributor-Breakerless FI MFI Electronic MPI,FUEL VAPOR CANISTER
Buick,Skyhawk,1987,Limited,Turbocharged SOHC 2.0L L4 Opel M GAS Distributor-Breakerless FI MFI Electronic MPI,FUEL VAPOR CANISTER
Buick,Skyhawk,1986,Sport,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skyhawk,1986,T-Type,Turbocharged SOHC 1.8L L4 Opel J GAS Distributor-Breakerless FI MFI Electronic MPI,FUEL VAPOR CANISTER
Buick,Skyhawk,1986,T-Type,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skyhawk,1986,Custom,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skyhawk,1986,Limited,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skyhawk,1985,Custom,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skyhawk,1985,T-Type,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skyhawk,1985,T-Type,Turbocharged SOHC 1.8L L4 Opel J GAS Distributor-Breakerless FI MFI Electronic MPI,FUEL VAPOR CANISTER
Buick,Skyhawk,1985,Limited,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Buick,Skylark,1988,Limited,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributorless FI TBI Electronic TBI,SKYLARK
Buick,Skylark,1988,Custom,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributorless FI TBI Electronic TBI,SKYLARK
Buick,Skylark,1987,Custom,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributorless FI TBI Electronic TBI,SKYLARK
Buick,Skylark,1987,Limited,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributorless FI TBI Electronic TBI,SKYLARK
Buick,Skylark,1986,Limited,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,SKYLARK
Buick,Skylark,1986,Custom,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,SKYLARK
Buick,Skylark,1985,Limited,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,SKYLARK
Buick,Skylark,1985,Custom,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,SKYLARK
Buick,Skylark,1984,Custom,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,SKYLARK
Buick,Skylark,1984,Limited,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,SKYLARK
Buick,Somerset,1987,Limited,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributorless FI TBI Electronic TBI,SOMERSET
Buick,Somerset,1987,Custom,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributorless FI TBI Electronic TBI,SOMERSET
Buick,Somerset,1986,Custom,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,SOMERSET
Buick,Somerset,1986,T-Type,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,SOMERSET
Buick,Somerset,1986,Limited,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,SOMERSET
Buick,Somerset Regal,1985,Base,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,SOMERSET
Buick,Somerset Regal,1985,Limited,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,SOMERSET
Chevrolet,Celebrity,1988,Eurosport,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Celebrity,1988,Base,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Celebrity,1987,Eurosport,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Celebrity,1987,Estate,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Celebrity,1987,Base,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Celebrity,1986,Estate,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Celebrity,1986,Base,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Celebrity,1986,Eurosport,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Celebrity,1985,Classic,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Celebrity,1985,Estate,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Celebrity,1985,Base,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Celebrity,1985,Eurosport,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Celebrity,1984,Eurosport,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Celebrity,1984,Base,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Citation II,1985,X-11,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Citation II,1985,Base,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Citation II,1984,X-11,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Chevrolet,Citation II,1984,Base,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
GMC,S15,1985,Base,Naturally Aspirated OHV 2.8L V6 General Motors B Chevrolet GAS Distributor-Breakerless CARB 2BBL Mechanical Rochester,
GMC,S15,1985,Sierra Classic,Naturally Aspirated OHV 2.8L V6 General Motors B Chevrolet GAS Distributor-Breakerless CARB 2BBL Mechanical Rochester,
GMC,S15,1985,High Sierra,Naturally Aspirated OHV 2.8L V6 General Motors B Chevrolet GAS Distributor-Breakerless CARB 2BBL Mechanical Rochester,
GMC,S15 Jimmy,1985,High Sierra,Naturally Aspirated OHV 2.8L V6 General Motors B Chevrolet GAS Distributor-Breakerless CARB 2BBL Mechanical Rochester,
GMC,S15 Jimmy,1985,Base,Naturally Aspirated OHV 2.8L V6 General Motors B Chevrolet GAS Distributor-Breakerless CARB 2BBL Mechanical Rochester,
GMC,S15 Jimmy,1985,Gypsy,Naturally Aspirated OHV 2.8L V6 General Motors B Chevrolet GAS Distributor-Breakerless CARB 2BBL Mechanical Rochester,
GMC,S15 Jimmy,1985,Sierra Classic,Naturally Aspirated OHV 2.8L V6 General Motors B Chevrolet GAS Distributor-Breakerless CARB 2BBL Mechanical Rochester,
GMC,Safari,1986,Base,Naturally Aspirated OHV 2.5L L4 General Motors E Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
GMC,Safari,1985,SL,Naturally Aspirated OHV 2.5L L4 General Motors E Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
GMC,Safari,1985,Base,Naturally Aspirated OHV 2.5L L4 General Motors E Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
GMC,Safari,1985,SLX,Naturally Aspirated OHV 2.5L L4 General Motors E Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
GMC,Safari,1985,SLE,Naturally Aspirated OHV 2.5L L4 General Motors E Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Oldsmobile,Calais,1987,Base,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributorless FI TBI Electronic TBI,
Oldsmobile,Calais,1987,GT,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributorless FI TBI Electronic TBI,
Oldsmobile,Calais,1987,Supreme,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributorless FI TBI Electronic TBI,
Oldsmobile,Calais,1986,Base,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Calais,1986,GT,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Calais,1986,ES,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Calais,1986,Supreme,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Calais,1985,Base,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Calais,1985,500,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Calais,1985,Supreme,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Calais,1988,SL,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributorless FI TBI Electronic TBI,
Oldsmobile,Cutlass Calais,1988,Base,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributorless FI TBI Electronic TBI,
Oldsmobile,Cutlass Calais,1988,GT,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributorless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1988,SL,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1988,LS,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1988,Base,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI
Oldsmobile,Cutlass Ciera,1988,S,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1988,Brougham,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1987,S,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1987,LS,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1987,Brougham,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1987,GT,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1987,SL,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1986,GT,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1986,LS,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1986,SL,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1986,Holiday,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1986,S,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1986,Brougham,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1986,ES,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1985,Cruiser LS,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1985,Holiday,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1985,ES,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1985,Brougham,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1985,LS,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1984,LS,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1984,Cruiser LS,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Ciera,1984,Brougham,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Cruiser,1988,LS,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Cruiser,1988,Brougham LS,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Cruiser,1988,SL,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Cruiser,1987,Brougham,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Cutlass Cruiser,1987,LS,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Firenza,1986,Cruiser,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Firenza,1986,Base,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Firenza,1986,LX,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Firenza,1986,Cruiser LX,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Firenza,1986,LC,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Firenza,1986,S,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Firenza,1985,Cruiser SX,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Firenza,1985,Cruiser LX,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Firenza,1985,GT,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Firenza,1985,Base,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Firenza,1985,Brougham SX,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Firenza,1985,ES,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Firenza,1985,Brougham LX,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,
Oldsmobile,Omega,1984,Brougham,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Oldsmobile,Omega,1984,ES,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Oldsmobile,Omega,1984,Base,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,FUEL VAPOR CANISTER
Pontiac,6000,1986,LE,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Pontiac,6000,1986,Base,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Pontiac,6000,1985,LE,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Pontiac,6000,1985,Base,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Pontiac,6000,1984,LE,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Pontiac,6000,1984,Base,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,
Pontiac,Fiero,1988,GT,Naturally Aspirated OHV 2.8L V6 General Motors 9 Chevrolet GAS Distributor-Breakerless FI MFI Electronic MPI,
Pontiac,Fiero,1988,Sport,Naturally Aspirated OHV 2.8L V6 General Motors 9 Chevrolet GAS Distributor-Breakerless FI MFI Electronic MPI,
Pontiac,Fiero,1988,Value Leader,Naturally Aspirated OHV 2.8L V6 General Motors 9 Chevrolet GAS Distributor-Breakerless FI MFI Electronic MPI,
Pontiac,Fiero,1987,GT,Naturally Aspirated OHV 2.8L V6 General Motors 9 Chevrolet GAS Distributor-Breakerless FI MFI Electronic MPI,
Pontiac,Fiero,1987,SE,Naturally Aspirated OHV 2.8L V6 General Motors 9 Chevrolet GAS Distributor-Breakerless FI MFI Electronic MPI,
Pontiac,Fiero,1986,SE,Naturally Aspirated OHV 2.8L V6 General Motors 9 Chevrolet GAS Distributor-Breakerless FI MFI Electronic MPI,
Pontiac,Fiero,1986,Value Leader,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Pontiac,Fiero,1986,GT,Naturally Aspirated OHV 2.8L V6 General Motors 9 Chevrolet GAS Distributor-Breakerless FI MFI Electronic MPI,
Pontiac,Fiero,1986,SE,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Pontiac,Fiero,1986,Sport,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Pontiac,Fiero,1985,Base,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Pontiac,Fiero,1985,SE,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Pontiac,Fiero,1985,SE,Naturally Aspirated OHV 2.8L V6 General Motors 9 Chevrolet GAS Distributor-Breakerless FI MFI Electronic MPI,OE# 17075840
Pontiac,Fiero,1985,Sport,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Pontiac,Fiero,1985,Sport,Naturally Aspirated OHV 2.8L V6 General Motors 9 Chevrolet GAS Distributor-Breakerless FI MFI Electronic MPI,OE# 17075840
Pontiac,Fiero,1985,GT,Naturally Aspirated OHV 2.8L V6 General Motors 9 Chevrolet GAS Distributor-Breakerless FI MFI Electronic MPI,OE# 17075840
Pontiac,Fiero,1984,,,FUEL VAPOR CANISTER
Pontiac,Grand Am,1986,Base,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Pontiac,Grand Am,1986,LE,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Pontiac,Grand Am,1985,Base,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Pontiac,Grand Am,1985,LE,Naturally Aspirated OHV 2.5L L4 General Motors U Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,OE# 17075840
Pontiac,Phoenix,1984,LE,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,PHOENIX
Pontiac,Phoenix,1984,Base,Naturally Aspirated OHV 2.5L L4 General Motors R Pontiac GAS Distributor-Breakerless FI TBI Electronic TBI,PHOENIX
Pontiac,Sunbird,1986,Base,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,SUNBIRD
Pontiac,Sunbird,1986,GT,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,SUNBIRD
Pontiac,Sunbird,1986,SE,Naturally Aspirated SOHC 1.8L L4 Opel 0 GAS Distributor-Breakerless FI TBI Electronic TBI,SUNBIRD
Borg Warner CP1038 Canister
[This message has been edited by theogre (edited 04-28-2019).]
