  Anyone change out auto shift handle to something else?
Anyone change out auto shift handle to something else? by 90turbo1
Started on: 05-25-2016 09:56 AM
Replies: 16 (745 views)
Last post by: 90turbo1 on 06-07-2016 09:36 AM
90turbo1
Report this Post05-25-2016 09:56 AM Click Here to See the Profile for 90turbo1Send a Private Message to 90turbo1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was looking at the rather large shifter handle for my automatic and was wondering if anyone changed out to a different one. I think the vette's had a smaller square one didnt they.....
let me know
Blacktree
Total ratings: 350
Report this Post05-25-2016 12:06 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are many other GM vehicles with auto shift knobs that will fit the Fiero shifter lever. Some of the more common ones are the F-body and Corvette knobs. Back when my Fiero had a slushbox, I used a shift knob from a Chevy Corsica.
Buck531
Report this Post05-25-2016 12:17 PM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just tried to swap my buick regal handle on and it fit but I couldn't get the key out of the ignition. It's clipped in at the right spot. Seems that it's not exactly the right size for it. Unless someone else has a different idea.
Lou6t4gto
Report this Post05-25-2016 02:19 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
f the Key won't come out, the shifter is not far enough into Park (has very little to do with the handle)
Total ratings: 463
Report this Post05-25-2016 07:28 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I acquired a 3rd gen F body handle, somewhere. I like it as much as any automatic handle I've ever seen.
(They were also available in leather. Probably a Corvette piece.)
[This message has been edited by Raydar (edited 05-25-2016).]
mmeyer86gt/gtp
Total ratings: 73
Report this Post05-25-2016 11:02 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
from a chimmaron recovered in new leather the shift rod was hacked down 1.5" and tited 10 degrees clockwise.
[This message has been edited by mmeyer86gt/gtp (edited 05-25-2016).]
Buck531
Report this Post05-25-2016 11:43 PM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
I played around with it at least a dozen times and gave up. It went in all the gears fine but when in park the key wouldn't come out. When I took the c-clip out and moved the handle slightly higher it was fine.
90turbo1
Report this Post05-26-2016 09:08 AM Click Here to See the Profile for 90turbo1Send a Private Message to 90turbo1Edit/Delete MessageReply w/QuoteDirect Link to This Post
are those bazooka bass tubes in front of the seats???????
mmeyer86gt/gtp
Total ratings: 73
Report this Post05-26-2016 09:35 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes yes they are and powered from the stock amp.
seajai
Total ratings: 51
Report this Post05-26-2016 10:13 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
1989 Olds Toronado
[This message has been edited by seajai (edited 05-26-2016).]
couldahadaV8
Report this Post06-03-2016 08:20 PM Click Here to See the Profile for couldahadaV8Click Here to visit couldahadaV8's HomePageSend a Private Message to couldahadaV8Edit/Delete MessageReply w/QuoteDirect Link to This Post
A bit(!) of trouble, but this is what I have:
Rick
RayOtton
Total ratings: 54
Report this Post06-04-2016 06:58 AM Click Here to See the Profile for RayOttonSend a Private Message to RayOttonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just added the same shift handle to my Formula. At first I was disappointed that i still had to use a finger to depress the button far enough to shift into 1st and 2nd.
Then I glued a 1/4 high button from my wife's Bakelite collection to the top of the button and now I can engage 1st and 2nd by pressing down with the palm of my hand. Sort of like the Rodney auto shift handle.
[This message has been edited by RayOtton (edited 06-04-2016).]
Kitskaboodle
Report this Post06-05-2016 02:58 AM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Grand Prix shift knobs are quite nice and fit without any mods as far as I can recall.
Kit
Fieroking
Total ratings: 78
Report this Post06-06-2016 01:25 AM Click Here to See the Profile for FierokingClick Here to visit Fieroking's HomePageSend a Private Message to FierokingEdit/Delete MessageReply w/QuoteDirect Link to This Post
I make a push button transmission selector to replace the cable and shift handle. Computer controlled using a linear actuator.
Joe Sokol
85 SE Daily driver with a 3.4 DOHC OBD II
88 Formula/GT 4.9 Allante Intake (My Baby)
www.fieroking.com
90turbo1
Report this Post06-06-2016 08:15 PM Click Here to See the Profile for 90turbo1Send a Private Message to 90turbo1Edit/Delete MessageReply w/QuoteDirect Link to This Post
so got a corvette knob, black leather button on center. was wondering if there was a write up on how to modify the stock shifter to accept the corvette knob?
I know right off the start I must cut down the stock shifter as the slots need to be at 9 and 3 versus the 12 and 6 position they are from the factory,
and then the button is slightly different how do you make it work with stock fiero shifter.
90turbo1
Report this Post06-06-2016 08:31 PM Click Here to See the Profile for 90turbo1Send a Private Message to 90turbo1Edit/Delete MessageReply w/QuoteDirect Link to This Post
90turbo1
Member since Jul 2015
0h yeah forgot to say the shift knob is from a 84-92 covette.
90turbo1
Report this Post06-07-2016 09:36 AM Click Here to See the Profile for 90turbo1Send a Private Message to 90turbo1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Joe Sokol
dang why didnt I know of you when I lived in Spokane WA......... dang it...
