  size of front stock coil springs ?
size of front stock coil springs ? by knarfluna
Started on: 06-19-2015 09:22 PM
Replies: 7 (635 views)
Last post by: Patrick on 06-22-2015 05:24 PM
knarfluna
Report this Post06-19-2015 09:22 PM Click Here to See the Profile for knarflunaSend a Private Message to knarflunaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am looking to match my front spring rate with the rear....I have new coil overs in the rear of my 87 fiero with a 315Lb rate. however the front feel too soft...so I have two options
buy Arrautmotorsports front coil overs with desired spring rate and adjustable.
or figure out what length are the stock springs in front and replace with a stiffer spring rate
so...does anybody know the length of the front springs....I would like to purchase a new set that will keep stock height.
Lou and Blue
Report this Post06-19-2015 09:27 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Scotty has a pair of front springs for sale. I'm sure he can measure them for you and post here.
I will have mine off in a few weeks and I can measure for you but it'll be a little while.
Louis Duet
Baldwin, Long Island, NY
"My mind spins like helicopter blades." -G. Rossdale
"Blue" <= '85 Fiero GT
3800sc series 2 swap in progress--IT'S ALIVE !!!!!
"Boo" <= '81 Delorean DMC-12
VIN #5835
Stock PRV engine
Peugot 604 Intake manifold
Exhaust headers
Anti-3rd brake light
[This message has been edited by Lou and Blue (edited 06-19-2015).]
Scott2scott
Report this Post06-19-2015 09:46 PM Click Here to See the Profile for Scott2scottSend a Private Message to Scott2scottEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just took it out if the box and put a tape on it for you. Looks like 13 in.
knarfluna
Report this Post06-19-2015 09:57 PM Click Here to See the Profile for knarflunaSend a Private Message to knarflunaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks S2S!
how bout inside diameter?
Scott2scott
Report this Post06-19-2015 10:38 PM Click Here to See the Profile for Scott2scottSend a Private Message to Scott2scottEdit/Delete MessageReply w/QuoteDirect Link to This Post
Inside the ring from side to side with a digital caliper is 3.4 in at bottom of coil and top looks like its abit smaller at 3.1 in
fierosound
Total ratings: 286
Report this Post06-20-2015 04:29 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I tried to build a database of STOCK spring data - but nobody participated
https://www.fiero.nl/forum/A...120111-2-110727.html
On my GT, I had 1" lowering spindles and with age, original springs sagged too much.
I need new springs to get it back to the ride height I wanted still using the lowering spindles.
I got Chevette springs https://www.fiero.nl/forum/A...120111-2-110255.html
Calgary time/temp
[This message has been edited by fierosound (edited 06-20-2015).]
Lou and Blue
Report this Post06-20-2015 10:18 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for chiming in Scott !!!
You are a super helpful person here ! And privately too !!
Good man.
Louis Duet
VIN #5835
Stock PRV engine
Exhaust headers
Report this Post06-22-2015 05:24 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
84-87 stock springs and codes
And a helpful thread post it is!
Just this past weekend I cut two full coils off of a set of 1984 DMN 12-3/4" long 12mm springs and installed them in the front of my '88 Formula. I autocross the Formula and I had previously installed a set of lowering springs (along with KYB shocks). I liked the stance, but I found the front springs to be a little too soft for autocross. I'm hoping these cut springs are going to be stiffer than the ones I swapped them out for, although I'm surprised that the front end appears to be a little higher than it was with the lowering springs. I'll wait to see if these cut springs settle any before I decide to cut more off than the two coils already removed.
