  Which adjustable clutch banjo to buy?
Which adjustable clutch banjo to buy? by echocharliepapa
Started on: 06-16-2015 08:57 PM
Replies: 6 (393 views)
Last post by: echocharliepapa on 06-20-2015 02:49 PM
echocharliepapa
Report this Post06-16-2015 08:57 PM Click Here to See the Profile for echocharliepapaSend a Private Message to echocharliepapaEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I'm ordering a new clutch pedal (and bushings) from The Fiero Store, and want to get an adjustable banjo clip from Rodney Dickman, too. Rodney sells two different styles, early (84-87) and late (88), based on the diameter of the pin on the clutch pedal bracket, but TFS only has one style of pedal that they advertise as 84-88. The picture on TFS is not large enough for me to tell which clip to buy, does anyone that's recently purchased a pedal from TFS know which style of pin it has on it?Pics of the two styles on Rodney's site.
Thanks!
Report this Post06-16-2015 10:18 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
zzzhuh
Report this Post06-17-2015 12:36 AM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is my thread concerning the issue I had with my 86GT
https://www.fiero.nl/forum/Forum2/HTML/134661.html
echocharliepapa
Report this Post06-18-2015 02:38 AM Click Here to See the Profile for echocharliepapaSend a Private Message to echocharliepapaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now I'm even more confused. The Fiero Store's clutch pedal doesn't need the bushing to the master cylinder rod/banjo clip, but what style is the pin? Or does it not matter?
Report this Post06-18-2015 05:50 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
This problem has been documented in the past, and I can't find the thread. I think the Fiero store pedal is the larger pin....but not positive yet.
Rodney
Total ratings: 267
Report this Post06-18-2015 06:32 PM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
TFS clutch pedal is the large diameter pin. So order my early/large diameter banjo kit. All Fiero clutch master cylinders will fit on that pedal but you will have steel to steel for a wear surface on the pin. My early adjustable banjo has a oilite bushing in it to fit the large diameter pin.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
echocharliepapa
Report this Post06-20-2015 02:49 PM Click Here to See the Profile for echocharliepapaSend a Private Message to echocharliepapaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, getting ready to order everything now. Went out yesterday morning to see if I could drive it, as some days are better than others (thought maybe temperature was causing metal parts or fluids to expand/contract? Was driving fine on warm days but then we had a cool spell and that's when the problems started up again), and there was no resistance in the clutch pedal, at all. Able to get it in gear with the engine off, so definitely just a clutch issue. Probably going to just order new master and slave cylinders while I'm at it.
