  EGR Tube Gasket question.
EGR Tube Gasket question. by Dslice
Started on: 06-08-2015 03:37 PM
Replies: 4 (963 views)
Last post by: Dslice on 06-08-2015 03:59 PM
Dslice
Report this Post06-08-2015 03:37 PM Click Here to See the Profile for DsliceSend a Private Message to DsliceEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm replacing the EGR tube Gaskets after doing some work to the fuel rail. I have to gaskets in the kit I got, ones 'cardboard' looking and the other metallic with a a restrictor, while all shaped correctly they look different than the ones I'm replacing.
I'm wondering which one of the two I have go on the EGR valve end and which one goes on manifold end. Also will the gasket with the restrictor have a unwanted effect.
I have a 86 GT V6.
Much Thank,
Rick
Rick D
86GT
Total ratings: 461
Report this Post06-08-2015 03:45 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You've asked a good question. I've often wondered about that myself. Recently I noticed the following at Rodney Dickman's site...
Originally posted HERE:
Replacement EGR gaskets. The small hole gasket goes on the intake manifold side of the EGR tube. This prevents a high idle condition if the EGR tubebreaks.
I have to assume that the restriction created with that smaller hole does not impair EGR performance (although on my own EGR system, I haven't used any gaskets with a smaller hole).
[This message has been edited by Patrick (edited 06-08-2015).]
Report this Post06-08-2015 03:48 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The restrictor goes between the tube and the intake manifold. The small hole in it prevents wide open throttle condition should the egr tube develop a leak.
Edit: Darned, Patrick, are you always that quick in everything you do? You had to be posting that about the time I clicked "Reply".
[This message has been edited by fierofool (edited 06-08-2015).]
Total ratings: 461
Report this Post06-08-2015 03:57 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heh heh... I timed that well.
Dslice
Report this Post06-08-2015 03:59 PM Click Here to See the Profile for DsliceSend a Private Message to DsliceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys!
