  Cracks around sunroof-repair
Cracks around sunroof-repair by notwohorns
Started on: 06-03-2015 01:06 PM
Replies: 4 (181 views)
Last post by: notwohorns on 06-03-2015 08:47 PM
notwohorns
Report this Post06-03-2015 01:06 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've searched and also searched under the username "Tha Driver" and couldn't find anything. I have cracks around the sunroof on the roof. Some look pretty deep. What is the proper way to repair those? Or could you give me a link about repairing them. Thanks
Report this Post06-03-2015 01:37 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
notwohorns
Report this Post06-03-2015 04:19 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, not nearly as many or as bad, but something like that.
Report this Post06-03-2015 04:28 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
That is caused by water getting through cracks in the paint and expanding the SMC plastic. You need to grind out all the loose stuff, fill with SMC compatible filler, and prime and paint just like anywhere else. The sunroof has to come out, because you need to seal the entire plastic surface or it will just happen again. Make sure the top is very dry before you fill it.
notwohorns
Report this Post06-03-2015 08:47 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Gall. I read what filler to use. I guess grind down to good material
