  Jerky when AC is on
Jerky when AC is on by ninjayogi
Started on: 05-01-2015 02:43 PM
Replies: 5 (214 views)
Last post by: Patrick on 05-02-2015 08:39 PM
ninjayogi
Report this Post05-01-2015 02:43 PM Click Here to See the Profile for ninjayogiSend a Private Message to ninjayogiEdit/Delete MessageReply w/QuoteDirect Link to This Post
When my fiero is running with no AC it runs fine, once AC is on the car becomes jerky. I have a stock 2.8 It has a new distributor, cap and point as well as new spark plugs, wires and injectors. TIA
tshark
Report this Post05-01-2015 02:55 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 465
Report this Post05-01-2015 03:02 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by ninjayogi:
...once AC is on the car becomes jerky.
That's a pretty crummy description.
Does the idle speed go up and down while the car is sitting still with the A/C on? If so, is that in tandem with the A/C cycling on and off rather quickly? The A/C might just be low on refrigerant.
ltlfrari
Total ratings: 127
Report this Post05-02-2015 12:03 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
DA6 or V5 compressor Da6/HR6 based a/c systems used a cycling system that causes the a/c to switch on and off as the pressure rises and falls, V5 based systems do not and much smoother in operation. Is there a switch on the accumulator up front? If so it is DA6/HR6 cycling system, if not then v5. With a cycling system you often (especially on a Fiero) feel the additional drag as the compressor engages. Is it 'jerky'? I don't think so but it depends on how you define jerky really. If it's just a feeling of additional resistance then that is normal.
Dave
www.ltlfrari.com
ninjayogi
Report this Post05-02-2015 08:35 PM Click Here to See the Profile for ninjayogiSend a Private Message to ninjayogiEdit/Delete MessageReply w/QuoteDirect Link to This Post
It appears that the Freon level was low, I added more and it got much better. I would have never thought that it being low could cause negative performance issues. Thanks for all your help.
Total ratings: 465
Report this Post05-02-2015 08:39 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do I get a ribbon or a medal of some sort?
