Question for people who have used tthe 4th gen Firebird cluster by Mike Gonzalez
Started on : 05-01-2015 12:24 PM
Replies : 14 (372 views)
Last post by : Mike Gonzalez on 05-07-2015 05:58 PM
May 1st, 2015
Mike Gonzalez Member Posts: 5093 From: Colorado Springs, CO. USA Registered: Jul 2001
I am thinking about trying the Firebird cluster. Would like to get the 150 speedo but they only came in V8 cars. I am runninng a 3800 and just wondering if the tach would read correctly or if there is a way to convert a V8 tach to work on the V6? I have searched and read a few threads and PM'd some of the people in those threads, but no luck so far. TIA
12:24 PM
Mickey_Moose Member Posts: 7583 From: Edmonton, AB, Canada Registered: May 2001
As I recall the tach is fed from the ECM and more than likely you are going to have to modify it. I believe I posted the info in jscotts build thread.
01:45 PM
Okay, ill look for it....Is there a stand alone module that i could buy that would run the tach if thaats the case?
05:12 PM
Boogaloo Member Posts: 422 From: South Miami,Fl Registered: Sep 2009
Yes there is try Dakota Digital,I am running a 155mph Z28 speedo and it works fine for me.
05:28 PM
Nice, what year cluster did you use ?
06:59 PM
May 2nd, 2015
A 2002 Camaro Z28 a little different from the Firebird.
05:06 AM
Oh, cool, and the dakota digital module runs all the gauges? do you have a link to what I need?
09:13 AM
May 4th, 2015
Nice, thank you....and if I get a 98 cluster is there a simple way to mod the fuel gauge, or just swap it wit an earlier model the easiest?
Nevermind, looks like you covered that in the same post.....
So if using a V8 cluster on a V6 measure the resistor and divide by .75?
[This message has been edited by Mike Gonzalez (edited 05-04-2015).]
05:11 PM
quote Originally posted by Mike Gonzalez: Nice, thank you....and if I get a 98 cluster is there a simple way to mod the fuel gauge, or just swap it wit an earlier model the easiest? Nevermind, looks like you covered that in the same post..... So if using a V8 cluster on a V6 measure the resistor and divide by .75?
Tach - I think that should get you within the ball park.
Yes you have to swap the fuel gauge and make the changes shown.
I also see that jscott1 mentions in the following post that the V6 tach is good to go with V6 engines.
05:21 PM
Yaa, i just want the 155 speedo, worth having to mod the tach in my opinion :-)
05:24 PM
May 6th, 2015
Yes it is simple enough to modify the tach and if you put a pot in there you should be able to dial it right in to match your rpm reading on a scanner.
04:48 PM
I hopee so, got one on the way.....do you have any better pics of the solder points then in that thread? Maybe once its in front of me I'll be able to tell what you did.
05:34 PM
May 7th, 2015
quote Originally posted by Mike Gonzalez: I hopee so, got one on the way.....do you have any better pics of the solder points then in that thread? Maybe once its in front of me I'll be able to tell what you did.
I can look, probably not (maybe higher res so you can zoom in).
04:52 PM
quote Originally posted by Mickey_Moose: I can look, probably not (maybe higher res so you can zoom in).
That would be great !
05:58 PM
