Thread Closed  Topic Closed
  Swapping in a newer Getrag transmission
Post New Topic
Printable Version
This thread has been moved here: FAQs & HowTos.
Swapping in a newer Getrag transmission by fierosound
Started on: 04-15-2015 01:05 PM
Replies: 2 (421 views)
Last post by: fierosound on 04-15-2015 01:14 PM
fierosound
Total ratings: 286
Report this Post04-15-2015 01:05 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Information pulled together from several threads (thanks guys).
Rodney's information
http://www.rodneydickman.com/getraginfo.htm
Sometimes you'll find a Quad-4 Getrag that's too good to pass up (new or low miles)
(these are circa 1992 Getrag trannys - note location of arm on clutch fork)
You can have a transmission shop to change the bellhousing half of the Quad-4 Getrag transmisson.
You'll need the bellhousing from a V6 Getrag (you probably have a worn out V6 tranny anyway)
When you swap an original Fiero bellhousing, you'll only need the Cable Linkage Conversion Kit below.
Here's the scoop on parts needed for newer FWD V6 Getrag transmission as pictured above in our Fiero application.
In some cases you may have to split the case to change the gear for the VSS. (speedometer)
Dickman has the gear $25: http://rodneydickman.com/ca...h=28&products_id=330
Instructions http://www.rodneydickman.com/n36.html
With pictures http://centralfloridafieros...dex.php?topic=1119.0
You use this transmission with stock Fiero Getrag 5-speed shift cables and stock clutch slave cylinder.
Use the stock Fiero select cable bracket - or new one from Rodney if you don't have one. $24
http://www.rodneydickman.com/n13.html
You will need these FWD transmission conversion items from Rodney...
- cable linkage conversion kit $75
- shift cable bracket $67
- slave cylinder adapter $55
http://rodneydickman.com/ca...th=28&products_id=58
http://rodneydickman.com/ca...th=28&products_id=52
Dickman's brackets (in blue) pictured below. Slave cylinder bracket not shown here.
Calgary time/temp
[This message has been edited by fierosound (edited 04-15-2015).]
fierosound
Total ratings: 286
Report this Post04-15-2015 01:12 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
The bracket for the Select Cable will need to be bolted on.
The transmission already has pilot holes that need to be drilled and tapped for the bolts.
Here are close up pics of what has to be drilled, and one with the select bracket installed.
fierosound
Total ratings: 286
Report this Post04-15-2015 01:14 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierosound
Member since Nov 1999
Reverse light switch...
Original switch GM part number is 10075403 (from P22 parts book - but GM likes to recycle numbers)
http://www.gmpartsdirect.co...&partnumber=10075403
http://www.gmpartsgiant.com...tch-as-10075403.html
Fiero Store original type switch http://www.fierostore.com/P...%20%205SPD&d=342&p=1
An alternative http://www.reddevilriver.com/Related_Products.html
Post New Topic
