  Someone Help!
Someone Help! by pshamoun
Started on: 04-09-2015 01:16 PM
Replies: 4 (236 views)
Last post by: pshamoun on 04-10-2015 12:57 PM
pshamoun
Report this Post04-09-2015 01:16 PM Click Here to See the Profile for pshamounSend a Private Message to pshamounEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi I have an 88 pontiac gt v6 manual . It is converted into a ferrari testarossa.
My question is since the car was extended to fit the right dimensions of the testarossa; how do you extend the shift and select cables?
Because right now the cables are stiff and it is real tough to put in gear.
I just ordered new/used cables so when they arrive how should I extend it?what should I use to make it easier to shift?
If you can give me advice respond asap please!
Thanks Phil
hiwil88formula
Report this Post04-09-2015 01:40 PM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
You are going to have a custom set made. Contact California push pull http://www.push-pull.com/
pshamoun
Report this Post04-09-2015 02:10 PM Click Here to See the Profile for pshamounSend a Private Message to pshamounEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for your help! I greatly appreciate it!
sardonyx247
Total ratings: 219
Report this Post04-10-2015 02:31 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Also check your engine to body ground strap, if it is broke or not there, it will ground through the shift cables and then they get hot and expand and make it hard to shift.
pshamoun
Report this Post04-10-2015 12:57 PM Click Here to See the Profile for pshamounSend a Private Message to pshamounEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow you guys are a ton I help
Thank you Thank you
You Rock!
