  oil pan
oil pan by jon m
Started on: 03-28-2015 10:13 AM
Replies: 4 (657 views)
Last post by: Csjag on 03-30-2015 09:53 AM
jon m
Report this Post03-28-2015 10:13 AM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi - quick question - I am about to fit my oil pan to my 87 - 2.8 engine and the gasket I have is a fel pro therma dry.
is it wise to put RTV sealant or fit the gasket totally dry?
thanks in advance
jon
[This message has been edited by jon m (edited 03-28-2015).]
jon m
Report this Post03-29-2015 03:14 PM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
notwohorns
Report this Post03-29-2015 08:40 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
That gasket goes on dry. Make sure both mating surfaces are clean of oil
Arns85GT
Total ratings: 202
Report this Post03-30-2015 09:48 AM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The molded rubber goes on dry, however, I like to mount it on the pan first with some sealant to keep it in place during the install.
Csjag
Report this Post03-30-2015 09:53 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just used a product from NAPA on my water pump gasket that was very sticky and good at holding the gasket on as well as having sealant properties on areas exposed to oil, gas and water. It was much easier to use than rtv and it held the gasket on better.
[This message has been edited by Csjag (edited 03-30-2015).]
