  Getting a transmission rebuilt?
Getting a transmission rebuilt? by 82-T/A [At Work]
Started on: 03-15-2015 02:00 PM
Replies: 8 (321 views)
Last post by: Steven Snyder on 03-18-2015 08:09 PM
Total ratings: 200
Report this Post03-15-2015 02:00 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys, I have a 1987 Fiero Getrag 5-Speed that I pulled from a car that I stripped and cut-up (had no title). It's the transmission that I'll be using in my manual transmission swap of my 87 Fiero SE.
Question is... WHERE can I go to get the transmission rebuilt? As far as I can tell, the transmission "works." The car had 110k miles on it, and the clutch looked like it had never been changed. I can't tell if there was any crazy bearing issues or anything. Can I just get it rebuilt at any old transmission shop, or is there something uniquely special about it that it needs to be treated differently?
It's going to my 2.8 V6/60 that's been rebuilt with 3.1 crank and rods and .040 overbore pistons. I'm not expecting more than 190hp.
Thanks!
dratts
Total ratings: 118
Report this Post03-15-2015 05:52 PM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just slap it in. If it breaks get another one from pull n save. Way cheaper than a rebuild.
Total ratings: 200
Report this Post03-15-2015 06:16 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Getrag Fiero transmissions are getting REALLY hard to find, and people are charging insane money for them.
no2pencil
Report this Post03-15-2015 06:20 PM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you are willing to pay for shipping, I can recommend Jim & Sons's Transmission in Ohio.
[This message has been edited by no2pencil (edited 03-15-2015).]
Total ratings: 200
Report this Post03-17-2015 03:59 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
That actually looks like a REALLY professional shop! Thanks for the link!
Old Lar
Total ratings: 214
Report this Post03-17-2015 09:41 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.mantrans.com/ in Tallahassee, FL
Total ratings: 200
Report this Post03-18-2015 01:42 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Lar! That's even closer. A days drive and I can go drop it off, and pick it up the same way! My parents are only an hour or so from there.
Thanks!
unboundmo
Report this Post03-18-2015 02:09 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
I've done the same recently.. Took mine to the local AAMCO and got RAPPED! ---$495 to split the case labor only, by new CV seals, Anaerobic RTV seal the halves and put it back together (don't forget the prep activator spray).. But then they wanted another $520 for the detent cover! I asked for my tranny back and found this VERY helpful thread below--- FYI, the detent cover part number is 14082039 OEM GM part... I found one for $32.95 plus shipping. The sealant and seals you can find at NAPA.
https://www.fiero.nl/forum/Forum9/HTML/000008.html
I had no problems with the gears so no dismantling there. Actually doing the job myself was CAKE!
----this was my thread here.. https://www.fiero.nl/forum/Forum2/HTML/134770.html ....but it isn't any sort of instructions.. just a couple great pointers from forum peeps.. as they are always helpful - thanks guys, keep up the great work!
[This message has been edited by unboundmo (edited 03-18-2015).]
Steven Snyder
Total ratings: 106
Report this Post03-18-2015 08:09 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
These are very long lasting transmissions. I would just put it in the car. A rebuild is more hassle than it's worth if you don't really need it.
