  Manual 282 Swap 86 Duke
Manual 282 Swap 86 Duke by Squishyxout
Started on: 03-13-2015 07:56 AM
Replies: 14 (503 views)
Last post by: fierosound on 03-17-2015 06:16 PM
Squishyxout
Report this Post03-13-2015 07:56 AM Click Here to See the Profile for SquishyxoutSend a Private Message to SquishyxoutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Alright guys, I'm looking to swap a Getrag 282 into my Notchie, because let's face it, the Duke isn't that much fun, and Auto trannies aren't going to help their cause.
I have looked through most of the stuff I'm going to need to swap it in but I still need a few parts I can't just buy at my local parts store.
What I need is the pedal assembly for a manual, and a shifter assembly.
following the previously stated, I don't know if I can use any fiero shifter assy but I need one for a 5 speed, if the 4 speed one will work, I'll be fine with that.
I found the tranny on ebay, "Certified New" and I'm going to buy it because I haven't seen such a good deal in a long time. $400 shipping included. I've been looking things up and it's going to be about $1100 in total for the swap.
(that's including the transmission itself)
if there is anyone that has the parts I need, please PM me, and I will get back to you within 24 hours.
Also, this will become my build thread once I start the swap.
Rodney
Total ratings: 267
Report this Post03-13-2015 08:37 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
That Getrag you are looking at on eBay is most likely a Quad 4 trans and will not fit the Duke engine.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
no2pencil
Report this Post03-13-2015 08:40 AM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
When we swapped from auto to manual, we also had to swap the axels. Also I believe that the ECM should match what equipment you are using.
fierosound
Total ratings: 286
Report this Post03-13-2015 04:10 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
ECM runs the engine and controls torque convertor lockup with automatic.
No need to change ECM or it's PROM chip when going to a manual trans.
no2pencil
Report this Post03-13-2015 04:51 PM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank yiu for correcting me! Sorry to give out inaccurate information.
Total ratings: 463
Report this Post03-13-2015 05:16 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The honest truth is that it would be a heck of a lot easier and cheaper to have bought a banged up Fiero with a 5-spd Isuzu and swapped everything you need off the donor Fiero to yours.
Squishyxout
Report this Post03-14-2015 01:03 PM Click Here to See the Profile for SquishyxoutSend a Private Message to SquishyxoutEdit/Delete MessageReply w/QuoteDirect Link to This Post
It says Fiero in the listing, but it does say it's for the quad 4 engine. I purchased it last night, and now I am unable to locate the contact seller option.
What is it that makes it so this transmission doesn't work with the Duke?
I also have been looking for a reasonably priced Manual Fiero for almost 3 years now, and I can't even find one that's been wrecked near me.
Squishyxout
Report this Post03-14-2015 01:13 PM Click Here to See the Profile for SquishyxoutSend a Private Message to SquishyxoutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Squishyxout
Member since Sep 2014
Also, I was told that these transmissions would work but you have to get an adapter thing that allows you to use the FWD tranny with the M/R set up.
Report this Post03-14-2015 01:17 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
These should be pretty reasonable.....and not too far from you.
https://www.fiero.nl/forum/F...1/HTML/095071-2.html
Squishyxout
Report this Post03-14-2015 01:56 PM Click Here to See the Profile for SquishyxoutSend a Private Message to SquishyxoutEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't have a truck... if I can't get a ride there and drive it back I can't buy it.
Total ratings: 463
Report this Post03-14-2015 04:04 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It might be a lot easier in the long run to get around that obstacle than to try and follow your original plan.
[This message has been edited by Patrick (edited 03-14-2015).]
KurtAKX
Total ratings: 128
Report this Post03-15-2015 09:20 PM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
That would be true if the trans was from something like a V6 cavalier z24.
You have a bigger problem. The quad 4 trans won't bolt to your engine. The quad 4 has a different bellhousing pattern.
[This message has been edited by KurtAKX (edited 03-15-2015).]
jaybug56
Report this Post03-15-2015 10:33 PM Click Here to See the Profile for jaybug56Send a Private Message to jaybug56Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have the 5 speed trans, axles, cables and shifter. no pedal assy. Fairly close also.
Steve2bnm
Report this Post03-17-2015 09:45 AM Click Here to See the Profile for Steve2bnmClick Here to visit Steve2bnm's HomePageSend a Private Message to Steve2bnmEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have bought one of the $400 trans on ebay and it is in my living room. I can measure the bolt pattern for you if you like.
I am going to use it to replace my failing Getrag for my 88 Formula. I will be swapping the bell housing so it will bolt up to my V6.
fierosound
Total ratings: 286
Report this Post03-17-2015 06:16 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed. The Fiero Iron Duke uses the same bellhousing as the 2.8 V6 - NOT the Quad 4
Yup - they're the same Getrag 5-speed, but the bellhousings are very different.
[This message has been edited by fierosound (edited 03-17-2015).]
